Posts: 802 Location: The Welsh Marches, in the hills above Newtown, Powys.
Thu 13 Nov, 2014 1:53 pm
Quote: |
I’ve got a reproduction of this piece by Emrys which I need to get restored sometime soon: |
aaarrghhhhhhH!!!!!!!!!!!!!
Yes. Yes you do.
:eek: :eek: :eek: :eek:
Posts: 21 Location: Perth
Thu 13 Nov, 2014 4:46 pm
Sun 16 Nov, 2014 9:33 pm
Mon 17 Nov, 2014 6:49 pm
Mon 17 Nov, 2014 10:24 pm
Hi Mike,
Good to see the pics of you wearing the sallet - and great that it turned out so well!
For look and fit of bevors, my guess is that they're an underrated piece of armour in terms of the difficulty of build - they need to be made in conjunction with the sallet, so that you have a good range of motion ... it's tricky, as they need to ride fairly far back so that you can turn your head and not have the sallet catch on the bevor, but not be so far back as to crunch your nose if you take a hit.
The rest of your armour - and arming garments - need to also be taken into consideration, as this will dictate the dimensions, angle it sits at, and where and when it is strapped and possibly attached to the breastplate.
So often, it seems that bevors are not built as part of a sallet commission, are sometimes added as an afterthought, or are sourced from cheaper suppliers as some kind of 'one size fits none' aftermarket addition. I'm keen to see them produced more, with the kind of planning and design that goes into other parts of harness.
Mon 17 Nov, 2014 10:41 pm
Yeah it's something I should have studied more really. My Bevor actually fits well, other than the large plate part that I believe is meant to mount to the top of a breast plate. Obviously Mac couldn't shape that part to fit me perfectly...alittle tempted to remove it so the bevor can fit a lot closer to my neck & not sit on my chest. I need to play around with the fitment of it abit more. I *really* like the look of this one I have to say.
Attachment: 88.85 KB
![09_a_seite.jpg](files/09_a_seite_146.jpg)
Tue 18 Nov, 2014 5:45 pm
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
