Some two years ago I´ve bought 6 semi-finished arquebuse barrels (app. 100 cm long, with 14-16 mm calibers) from a son of a deceased local blacksmith / weapon maker. They were only roughly shaped, without even touch holes drilled, etc. Last weekend I´ve finally managed to work on them. The plan is to create 3 fully functional matchlock arquebuses from different periods: a) first half of the 16th c., with serpentine matchlock and button trigger; b) end of 16th c. petronel type arquebuse (with strongly curved stock - this http://www.vikingsword.com/vb/showthread.php?t=16183 shows the overall shape); c) early 17th century caliver / schutzrohr / arquebuse that would be typical for German lands.
I have not decided yet what to do with the remaining 3 barrels, but their time will come:)
So the work has started. First picture shows comparison of barrels as I´ve received them, and one semi-cleaned. They were cleaned on a lathe (parts with circular cross-section) and then by hand, using sandpaper. By cleaning then, I have also removed rough scratches from miller and lathe.
The second picture shows them semi-polished (A - early 16c, B - petronel, C - early 17c, D - I-dont-know-yet:)) I will work on them more later, after attaching flash-pans etc.
After that, I´ve drilled touch holes and holes for screws that will hold the back of the barrel to the stock (no pictures taken) and cut and shaped eyelets that will be soldered to the bottom of the barrels and secure then to stocks. These are quite simple, just a piece of mild steel, 20*10*4 mm, with a hole in the middle (I will take pictures later).
I have started to work on flash-pans. Obviously, these three different guns will have them shaped differently, but to simplify my work, I wanted to make some "generic" piece that could be shaped later. Given my limited access to tools (no miller), flash-pans were a hard nut. I came up with following: I took a piece of mild steel with square cross-section. I have drilled a hole (12 mm diameter) app to two thirds of its length. Then I´ve cut it in half, alongside the hole - and I had two rough stocks for flash-pans. I tried to sketch it on picture 3, and the last picture shows the cut pieces. It´s not perfect, but I will have to do for now.
Next steps: shaping the flash-pans, and soldering them, together with eyelets, to barrels (soldering will be done by a friend of mine, who is definitely much better in that).
Any comments and suggestions are welcome. I would especially appreciate any nice detailed pictures of petronels - matchlock mechanism, decoration, stock details, etc. I have some, but the more the better:)
