Hello
I've been doing some reading on the usage of greaves recently, was it true that the greaves weren't common during 11th-13th century? It also seems like mail was used a lot more for leg protection, and according to Wikipedia during the 13th century greaves only protected the front shin, was this true? From what I saw from the osprey books most of the 14th century knights had a full closed greaves while most earlier knights had mail leg instead. Also my my last question is what kind of people wore greaves (demi or full)? Was it exclusive for knights? Thanks.
Ed
Greaves are in use during roman times, but fall from common use during the dark ages.
They reappear sometime in the late 13th century, as supplement to mail chauses for knights. In the same period knee and elbow protectors of plate start to appear, and untill about mid 14th c. knights mix and match these reinforcements according to taste.
In the late 14th c, full leg and arm harness becomes the norm.
I do not recall seeing many soldiers with loose greaves without the rest of the harness, but it is not my main period.
One thing to keep in mind is that while we cosider greaves and vembraces very logical pieces of armour for sword figthing, the main weapons on the battlefield where spears and lances. This could partialy explain the lack of focus on limb defences in atique and dark age armours.
If you would like to look at some sources yourself, I recomend having a look at
http://manuscriptminiatures.com/
and its sister site
http://effigiesandbrasses.com/
both excellent resources.
and its sister site
In English, these shin defenses are found in records as schynbalds, skinbaux, etc.. They first appear c. 1250, slightly after the earliest plate armor on the knees which appears about a quarter century earlier. These continue in use in the first half of the 14th century alongside fully enclosed greaves. Some examples on Manuscript Miniatures have already been tagged.
http://manuscriptminiatures.com/search/?tags=...alds"
Thanks for the reply guys.
I'm trying to imitate this kind of leg defense, but I'm not sure what kind of material this is, or if this is just a theory of what they had back then. I'm assuming this leg defense is made of leather?
http://minimumwagehistorian.files.wordpress.c...ttiere.jpg
Edward Lee wrote: |
I'm trying to imitate this kind of leg defense, but I'm not sure what kind of material this is, or if this is just a theory of what they had back then. I'm assuming this leg defense is made of leather? http://minimumwagehistorian.files.wordpress.c...ttiere.jpg |
Leather just isn't very protective for the weight. I'd sooner guess those are shells of light gauge steel, painted and laced together.
We do know shin defenses were sometimes made of leather from inventories, but it's impossible to tell from a picture if we're seeing leather, or cloth or leather coverings on plate, which are also documented. The early 14th century Modus armandi milites ad torneamentum calls for muscylers, in tibiis de ascer ou de quyr boily -- limb armor for the shin in steel or of cuir bouilli. I suspect Turner used Italian miniatures such as this one as a guide for the referenced painting.
http://manuscriptminiatures.com/4170/7886/
Thom Richardson's thesis mentions schynbalds, greaves, and a third defense known earlier as tibia, and later as jambers (geambers). His theory is that the tibia-jambers were of splints riveted to leather, while the greaves and schynbalds were of plate or cuir bouilli.
Laced hinges as shown on the Turner painting also appear on gray greaves apparently made of iron, See this thread from the late Tony Bryant on Armour Archive for examples.
http://forums.armourarchive.org/phpBB3/viewto...mp;t=86587
Thanks for the replies guys. Wow I never knew they used lacing on leg harness.
