Since the chariottes were no longer deployed for field battle, it is reasonable to consider this image was presenting the internal troops...
there are some points:
hand-halberd, it was only appeared during the Han Dynasty and seldom mentioned
saber and tassel, the shape of fittings are worth researching.
Gouxiang, a special type of buckler
han saber blades
Hm. interesting finds.
I haven't seen much along the lines of these before.
Might have to do some reading myself.
a clearer copy
Very interesting. That's quite an interesting depiction of ancient Eastern warfare. Thanks for posting!....McM
and this... it is my latest finding in an Antique auctions website: Han dynasty halberd head and cord about two thousand years ago.
I am amazed at how delicate thew sabre blades look. I am sure they weren't but they do look it.
Greg E wrote: |
I am amazed at how delicate thew sabre blades look. I am sure they weren't but they do look it. |
er.......the blade are 6~8mm thick or even more......... it's much thicker than weapons of this kind.
2007, a guy re-ground a Han dynasty saber blade (but of course, doing that with a 2000-years-old antique is very controversial...). And there are some of the images he posted.
overlength:1207mm
bladelength:1007mm
wide, lower:27.5mm
thick, lower:8.8mm
wide, upper:19.2mm
thick, upper:5mm
weight:925g
OMG....I would be nerved out to the point of drinking to ever grind on a blade that old. Looks like he did a good job, though!.............McM
Mark Moore wrote: |
OMG....I would be nerved out to the point of drinking to ever grind on a blade that old. Looks like he did a good job, though!.............McM |
BTW,i get a question about this: Is this kind of geometrical sword tips a unique Chinese style, or broadly used in other cultures? U know, it suddenly appeared in the 2nd century BC. and never existed before. was it affected by some foreign influences? I'm not sure.
Thank you for posting this. I find early Chinese steel metallurgy fascinating.
These "knife"-swords are very beautiful. Essential form and function.
I would love to try and make one.
Is there any remains of or clues to the kind of scabbards and/or carry system used for this kind of sword?
I have only seen images of blades.
I guess the hilt was wrapped with silk cord? Is this a probable assumption? Or a combination of wood or leather + over binding of silk?
The ring hilted knife had a very widespread popularity. A couple of centuries earlier Celtic warriors were using ring hilted knives: some say they were large carving knives. I think they had another more sinister use, knowing the popularity of taking the heads of defeated enemies in battle....
(The celtic knives looked very different from these Chinese swords, naturally. More like monster versions of the small ring hilted utility knife that was in use from central europe to the far easter reaches of the eurasian continent from the bronze age and onwards).
Thanks for posting this fascinating material!
X Zhang wrote: |
BTW,i get a question about this: Is this kind of geometrical sword tips a unique Chinese style, or broadly used in other cultures? U know, it suddenly appeared in the 2nd century BC. and never existed before. was it affected by some foreign influences? I'm not sure. |
I don't know of anything like this earlier than the Chinese ones. The Chinese ring-pommel sabres are the first long swords of this general style. The steel ones might be the earliest; there are long bronze ring-pommel dao, but they appear to be of similar age, and are thought to be bronze copies of the steel dao (possibly for funerary use, rather than martial use).
Similar tips appear on some Han bronze handled knives (basically knife-size versions of the long sword), but I don't know of such tips earlier. It's possible that such knives are the ancestor of the long sword, but one would like to see a few earlier examples.
A possible ancestor of such Han knives and swords is the Ordos ring-pommel bronze knife. I haven't seen this "tanto" point (as modern knife makers call it) on any Ordos knives.
Ring-pommel steel dao appear at about the same time among the Xiongnu and others, and where preservation allows, the same "tanto" tip is sometimes used. AFAIK, the Chinese examples are older. However, there is more diversity of tip styles in the Xiongnu swords, so they are also a possible ancestor (with the Chinese adopting one of their many varieties).
The same style turns up in Korea and Japan, later. These are either Chinese-made or Chinese-influenced.
Peter Johnsson wrote: |
Is there any remains of or clues to the kind of scabbards and/or carry system used for this kind of sword? I have only seen images of blades. I guess the hilt was wrapped with silk cord? Is this a probable assumption? Or a combination of wood or leather + over binding of silk? |
Have read that some examples have been found with traces of silk on grip and pommel. Yang Hong (Weapons in Ancient China) shows one example (pg 211) that has traces of a cord wrap (I assume silk) over what looks like a built-up grip core. Hard to tell from the drawing, and those details aren't given in the text. On the previous page is one with a cord wrapped grip and pommel. Looks like different cord on pommel and grip.
Early suspension was the usual scabbard-slide. Square or flared scabbard bottom fittings (as used on earlier jian). The one on pg 210 in Yang Hong has a scabbard slide, doesn't show the bottom (it's missing), and the scabbard is spiral-wrapped (with silk ribbon?). That's the only scabbard I've seen with evidence of the covering. P-mounts and other styles with 2 suspension rings on one side of the scabbard (so a classic sabre suspension) turn up later, but I think there are 3rd century examples.
Thanks Timo!
I see them clearly before me.
These "knife"-swords are very beautiful. Essential form and function. I would love to try and make one. Is there any remains of or clues to the kind of scabbards and/or carry system used for this kind of sword? I have only seen images of blades. I guess the hilt was wrapped with silk cord? Is this a probable assumption? Or a combination of wood or leather + over binding of silk? The ring hilted knife had a very widespread popularity. A couple of centuries earlier Celtic warriors were using ring hilted knives: some say they were large carving knives. I think they had another more sinister use, knowing the popularity of taking the heads of defeated enemies in battle.... (The celtic knives looked very different from these Chinese swords, naturally. More like monster versions of the small ring hilted utility knife that was in use from central europe to the far easter reaches of the eurasian continent from the bronze age and onwards). Thanks for posting this fascinating material! |
Er....Actually.....Y E S! i have some photos and pictures about that.
These are imitation from Northeast Asia about 1700~1500 years old. Decorative patterns may be different, but the general rig is quite similar.
This is an antique what was buried swamp in southern China. (it is exhumed from swamp is always well preserved.)
And....the carry system....
from 5th BC to 4th AD, chinese swjord/saber carry system was very extremely stable. We chinese call it "璏"(zhi) style(most Chinese did not know this ancient word although...... ). the “璏” means the “sword nose”, which is actually a belt loop.
Look at these pictures, the chariot driver of Terra Cotta Warriors.
And.......this is 璏
Great information! Thank you!
Great information! Thank you! |
bronze Scabbard chapes. From them you can understand the the cross section of scabbard.
Hope it can help
I have never seen any maker outside of china interest in Han dynasty saber. i am really looking forward to your works
Ran into a paper describing analysis of leather on a Chinese scabbard: http://www.sciencedirect.com/science/article/...2511003763
Summary: Alum-tanned leather over wood core. 6th century BC, for a bronze sword.
Page 1 of 2
