Eric S wrote: |
Using existing ring type material or punching rings and sewing them to a backing would have been a cheap, fast way of making armor. Not everyone could afford mail and not all fighting involved arrows and spears. |
The fact of the matter is that Europeans were manufacturing lots of small punched rings in the mid-13th century (contemporary with the Westminster Psalter image). These were used in making mail of demi-riveted construction (half riveted, half solid rings). It seems dubious that sewing 20,000 rings to a fabric base would be any faster than connecting them with wire rings. Admittedly, you might cut the weight in half along with the protective ability against spears and bows, the most common weapons of the early European Middle Ages. Yet we have no written evidence of such counterfeit mail, nor any reason to believe someone who could afford half a hauberk would not have equipped himself with documented armor like a gambeson instead. We're almost back to hypothesizing the 19th century theories of "banded mail" with sewn, overlapped rings on leather which were simply ludicrous based on the evidence. Perhaps we should revive Meyrick's trellised and mascled mail as well?!?
While mail was expensive, every English knight, as well as free laymen with property valued at 16 marks, were expected to have a mail hauberk (loricam) according to the 1181 Assize of Arms, with haubergeons (aubergel) being required at 10 marks. Burgesses were to have a gambeson (wambais) and iron hat. While we can't absolutely prove that these visual examples aren't discs with a central rivet or rings sewn to a backing, neither can we absolutely prove that they aren't regular old mail. The preponderance of the evidence indicates mail is most likely what is intended in this miniature.
