I named her, Dauðrnagl, which means Death Nail. I wanted my seax to be significantly different than most others out there, so it is an integration of both historical and fantasy design elements into my own personally-appealing design. I was thinking along the line of 13th Warrior meets LoTR Dwarves meets historical Vikings for the look.
A few weeks back, I ground the furniture out of mild steel on a wheel grinder and had my machinist cut the blade slot in the guard and tang hole in the pommel. I cleaned these up somewhat, then intentionally beat them up to give them a good antique look. I then heat-blued them and drew the finish back to a dull satin one, leaving the bluing within the pits and scratches on the pommel.
When the blade came, it still had the fire scale on it; which I had requested. It was a little too uniform, so I cleaned off the scale and chemically aged the piece to a nice deep grey color. I then cleaned up the edge and gave the bevel an even satin finish. Using a file, I notched the blade three times on the rear of the spine for aesthetics.
I fitted the pommel and guard (which amazingly fit nearly perfectly - I had cut the slots prior to the blades arrival). I wedged the guard into place then hot-peened the tang though the pommel for a solid fit. I did the grip scales and wrap the next day.
The original grip was rather austere, so I tore it off and re-did it with the same riser scheme I use on many of the Viking swords coming though my shoppe. I am quite happy with the overall look of the piece. It looks like something that could be found in the hands of a dwarf in the depths of Moria, at the side of Buliwyf has he fought off the Eaters of the Dead, or resting in the grave of a Viking warrior in the 9th century. It has been made to appear exactly what it is, an austere killing implement that looks as if it has a spirit of malice about it.
In the hand, it's quite versatile. It has enough presence and weight to be used like a short sword, yet remains nimble enough to be used as a large dagger or in conjunction with a hand axe in the off-hand. It's a vicious, no nonsense blade that would do it's job in either the fantasy or historical realms very efficiently. It's a brutal weapon, something made to fullfil it's one purpose without being pretty, ornate, or adorned.
I am thinking creatively on the scabbard for this one, but I can tell you now, it will be just as unique as this piece is. I will update when I get it completed. :)
Stats:
OAL: 29.50"
Blade Length: 22.25"
Grip Length: 6.50"
Weight: 2lbs, 3oz
PoB: ~3.5"
I hope you guys like it! :)
