The " mystery " Cinquedea as this was a pre-owned dagger and Kult of Athena didn't know who the original maker was except that it was made in the Czech Republic.
It's a very heavy bladed dagger and much more like a short sword and would hit like an axe as it has little distal taper: Now for a sword this might be a bad thing, but for a much shorter blade it gives it power and presence.
Total length is 21 1/2"
Blade length is 15 5/8"
Handle length is 5"
Blade width is 2 7/8"
Weight is 2 pounds 8 oz.
The etching on the blade is nice and clean with the background darkened in some way: Not sure if it's bluing or some paint or the colour left by the acid etch ?
The drawings are identical on both sides and I assume some sort of of transfer method used with a stencil ? Same for the etchings on the guard.
The blade came with varying sharpness that I'm evening out to a paper cutting edge and the steel's heat treat seems very good as it's harder to sharpen than a Del Tin sword I hand sharpened: So I think it's maybe 52 r.c. to maybe 55 r.c., the diamond hones do sharpen it but a chain saw sharpening file doesn't bite into the steel using medium pressure. My hardness estimations are based on hand sharpening many swords or knives of varying hardnesses in the past and a 50 r.c. blade feels a lot different than a 62 r.c. blades when honing.
The handle seems to be some nice hardwood that could be rosewood, but I'm really not sure.
The short handle with a very square sectioned handle is surprisingly comfortable and the brass cap over the end of the handle forming a kind of pommel ends up naturally in a handshake grip supported by the meaty base of the palm on the little finger side.
A couple of nice decorative " medallions " seem to be castings.
Overall a solid and robust Cinquedea with etched triple fullers transitioning to deep double fullers.
Again a purchase from Kult of Athena of a pre-owned dagger at a very affordable price, $179.95 : I also want to mention that Ryan on his site description of the Cinquedea was very ethical in mentioning some minor scratches and scuffing on the blade as well that the sharpness of the edges was not uniform. The " flaws " are barely noticeable by me, but it gives great confidence buying pre-owned products as Ryan is very scrupulous about mentioning any flaws he notices.
Close up of " medalion ".
Brass pommel.
