I've been told that roman gladius were designed for thrusting which makes sense looking at shape of it. But in contrast steel in Europe, at this time, was very poor and filled with impurities and I'd imagine that the mass production for the massive armies only increased the lack of quality.
On page 16 of The Sword and the Crucible, Alan Williams describes Roman metallurgy as "fairly mediocre" in quality.
Every typology of the gladius is designed for both cutting and thrusting. We have texts specifically saying that the sword was used for cutting and thrusting. Practical experimentation has shown the same thing.
The quality of Roman swords varied as much as the quality of medieval swords - from very poor to very good. There are examples of gladiuses with steel edges welded onto softer cores. There are examples of damascened gladiuses. They had smiths who were at least as capable as those who made the La Tene swords, and some of those are exceptional.
What's the infantry adage, "Remeber you weapon was made by the lowest bidder."
In the Roman army you paid for your own equipment. If you could afford it then you'd have better gear than the "standard issue" stuff that was deducted from your pay.
How good does it have to be to make a hole in someone? The worst Roman blades that I've seen analyses of were at least as good as modern mild steel, and most seem to have been better than that. Iron sword blades were hardly a new thing, so I suspect the Romans knew how to make functional weapons. Asymmetrical edges, some slag inclusions, and a crappy finish wouldn't hurt their ability to kill.
Roman equipment is a curious mixture of exquisite workmanship and government-issue crap. I've held original belt parts that made me weep with frustration, because we'll never be able to do them justice with our clunky reproductions. Original armor parts are delicate and small and fine and often decorated, yet often crooked with sloppy rivets. An iron armor plate will never have a straight edge, but will consistently be harder on the outside than on the inside--and so consistent in thickness that we are wondering if they made their sheet steel with rolling mills.
Our reproductions, by comparison, are never quite as nice as the good stuff, and never quite as crappy as the bad stuff! True historical accuracy is a real challenge.
Matthew
Matthew
Thank you all for giving me some insight on the quality and variation of roman arms and armor :D
Matthew Amt wrote: |
Roman equipment is a curious mixture of exquisite workmanship and government-issue crap. I've held original belt parts that made me weep with frustration, because we'll never be able to do them justice with our clunky reproductions. Original armor parts are delicate and small and fine and often decorated, yet often crooked with sloppy rivets. An iron armor plate will never have a straight edge, but will consistently be harder on the outside than on the inside--and so consistent in thickness that we are wondering if they made their sheet steel with rolling mills. Our reproductions, by comparison, are never quite as nice as the good stuff, and never quite as crappy as the bad stuff! True historical accuracy is a real challenge. Matthew |
A most excellent post!
The last part actually applies to far later ages as well.
This is fascinating.
