Greetings everyone!
In Croatia near Trilj are discovered two two-handed axes (they are discovered long ago, so its not a breaking news).Archeologist Ante Milosevic dates them into 7th century, while historian Tomislav Aralica think that they are from 10th century.Unfortunately, I dont have any literature about axes, so I cannot say who is wrong and who is right.They look to me like a something from Varangian inventory.Here is a picture of them:
Height of the crescent axe´s blade is 21,7 cm, so they are pretty large.What do you think?To which age are they belonging - late antiquity or early medieval ages?Which type are it?
P.S. Sorry for my bad english :) .
I'm not really knowledgeable about this, but I know that there are axes more or less similar to those ('crescent blade, thin eye, sometimes slight hammer on the other side) in Poland and generally all over Slavic territiories.
They're generally dated to around Xth century, dunno how accurately, but that would fit the later dating.
http://znaleziska.org/wiki/index.php/Topór_z_Poznania-Lubonia
http://znaleziska.org/wiki/index.php/Topór_(Lednica)
Bartek Strojek wrote: |
They're generally dated to around Xth century, dunno how accurately, but that would fit the later dating. http://znaleziska.org/wiki/index.php/Topór_z_Poznania-Lubonia http://znaleziska.org/wiki/index.php/Topór_(Lednica) |
Thanks for the help Bartek :).
i first also thought they had some norse touch about them, but did the varangians have any business in croatia ?
dober dan :)
dober dan :)
Hi
I don not think those analogies are proper :)
In his Drevnerusskoe oruzhie, Kirpichnikov writes they are type II of axes. They are dated to 10th- beginning of 11th century.
Even so, they could be earlier:
http://www.worldmuseumofman.org/display.php?item=7
Both of those examples from Poland present two different types. On one of them we can see a hammer (yours alike- this is "czekan"/ "Чекан"). While the second one has not any (this is normal axe, topór/ Топор)
Gottfried P. Doerler wrote: |
dober dan :) |
Dobar dan i tebi Gottfried :).
Unfortunately, I dont know.Not a single source mentions Varangians in medieval Croatia.But, those axes could be a result of trade between Svyatoslav I and Croats - after all, he did conquer Bulgaria with his Varangians and Russinas in second half of 10th century.
Arek Przybylok wrote: |
Hi
I don not think those analogies are proper :) In his Drevnerusskoe oruzhie, Kirpichnikov writes they are type II of axes. They are dated to 10th- beginning of 11th century. |
Which axes?Those from Trilj, or those from Poland, which were posted by Bartek?
http://www.worldmuseumofman.org/display.php?item=7 |
Wow, thanks for the link.That axe surely looks like a T-shaped one from Trilj :).
Anyway, here is a link to download an article of Aralica - but article is in croatian:
http://www.4shared.com/office/qbb17YWM/Sjekire.html
Here is a translation made by me:
"On the third picture there is a piece found in river Cetina near Trilj.It is a so-called T-shaped axe with double expanded blade.Neck of the blade has, on the upper end, pointy hump.Similar axe is found at the Nartski Novaki, and in the Middle Danube region.This type of axe is dated into first half of 6th century and it is proclaimed a probably local late-antiquity product (Milosevic, 1988., page 200).I dont agree with this, because analog piece from Nartski Novaki has form of slot and hammer-end (which is not to be found on late-antiquity axes), similar to some types of viking axes from 10th and 11th century (Kirpicnikov, 1966., page 30, his types III. and IV.).So, I think that it is proper to date this axe into 10th century.Btw, T-shaped axes are characteristic for Byzantium, where they could be found also in late medieval age, and they are also presented on frescoes (Skrivanic, 1957., picture 52)."
Translation is not perfect, but I think that you can understand it :).
Axe from Nartski Novaki could be found here, last one on the page 14:
http://www.google.hr/url?sa=t&rct=j&q...K2BZ4Pg7Aw
Axe is dated, along with other axes and materials, between 8th and 10th century.
I also think any dating before 10th century for these axes is very likely to be wrong. Similar axes in Poland in 10th or 11th century and the fact that these axes are two handed, point to the conclusion that these axes are probably same period and serve the same role as all other european two handed axes: 10th to 14th century, for use by a well armored infantrymen... After that period there are more poleaxes than regular two handed axes but here in eastern Europe you can see two handed axes quite late.
Matija Horvat wrote: |
Which axes? |
Those from Trilj :)
Arek Przybylok wrote: | ||
Those from Trilj :) |
Thank you very much :).Sorry for not answering you sooner, I had a little problem with my PC.
Thank you for this post, it helped with my research.
Those axes are probably byzantine. roughly 10th. cent imho.
few people reenacting byzantine guards heve replica, unfortunatelly i can not find photo right now.
as a general principal..UNLESS an object is found in a Dateable context..it's probably safer to assume a later, rather than an earlier date.
