For my next purchase I am considering buying the Hanwei Irish Viking sword. I like the asthetics and most importantly it looks to be quite light, which is great as my Albion viking sword is far too heavy for me to use. My main concern is that the sword looks quite short at only 28 1/4 inches blade length.
I wondered if this was historical so started flicking through my books and eventually while reading through "Records of the medieval sword" I noticed that a sword looked extremely similar and I saw that the blade length was the same, which further reinforced my suspicions that this is the sword than Hanwei copied.
Now my problem is that the sword in the Oakeshott book has a broken tip. I don't know if the blade measurement includes this or extrapolates the length of the blade as it should had been. I suspect that the 28 inch blade length does not take into account the missing tip.
It seems quite crazy that Hanwei in copying this sword would not make the sword the correct length, it is quite easy to see how long the sword should had been as the missing section is slight.
I could however be wrong as Hanwei say that the sword is copied from a sword found in Ireland, while the sword I found in the book was discovered in Norfolk England.
