This will be another 'making of' thread at the special request of myArmoury regular Jean Thibodeau.
Jean gave me about as open a brief as you could wish for, which was for an ear dagger. Jean asked for my opinion as to suitable specifications. We both seemed to be thinking along similar lines and so after a single mail pretty much nailed down the detail that was important to him and the rest will evolve during the project.
The dagger will be in many respects an unremarkable piece in that it is not a copy of a specific piece but will composite elements that were common to the style. It will have a hollow ground blade with an assymetrical ricasso, a very heavy blade section (about 8-9mm in this piece), a straight tang that has handle scales that protrude each side, and an enlarged 'pommel' that sits between the ears.
I have not got round to thinking too heavily about the scales or the scabbard yet, but the scabbard will again be fairly normal. Ear dagger scabbards were quite unusual in that they were often almost circular in section and so do not match the blade form like most scabbards do.
The progress pictures I have here show the basic blocking out of the blade profile, the handle holes having been drilled and the end of the tang having been upset to thicken it to allow the pommel section to be formed (some additional steel was added to bulk it out). The bevels were roughed out to remove some material and show approximately where they will go and I laid in the grooves on the top of the pommel.
The next step will be to heat treat the blade and finish the grind.
I hope you find it interesting.
blank roughed out
tang area reduced and holes drilled
'pommel' area upset and pommel formed
bevels roughed in
side view
pommel grooves laid on and polished
