Firstly this spearhead looks and feel much more substantial than the statistics or pics would lead one to believe and I'm certainly happy here as I was expecting something more " dainty " which would have been fine but I prefer a stouter spear head like this.
Lets first get some statistics out of the way:
A) Total length: 15 3/4".
B) Length of head alone approximately: 11".
C) Sharpened length approximately: 6 1/2" from tip ( After this the blade slowly become blunter and blunter and seamlessly transitions into the socket.
D) Width from tip of wing to wing tip: 5 3/8".
E) Width of neck leading to socket at it's narrowest: 11/16".
F) Socket: 1 1/16" wide " Flat to flat ", 1 1/4" Ridge to ridge, wall thickness approximately 1/16".
G) Weight: 1 lb 4oz.
The blade is an elegant oval in shape and the central ridge running from the hexagonal socket to tip is perfectly strait and everything is also perfectly symmetrical ( Perfectly seems to be a standard feature of all the work I have seen made by Michael ).
The finish is basically " Albion " like and easy to maintain and restore with a fine abrasive sponge should one need to remove scratches if one cuts with it.
The sharpened part of the spearhead is very sharp and even the blunter part on the half nearer to the socket gradually transitions from sharp, to butter knife sharp, to thicker still until it forms the sides of the hexagonal socket.
( Note the edges where sharp are of an appleseed kind with little to no secondary bevel ).
This head has a lot of mass and because of the curve and belly of the sharpened blade I think it would be devastatingly effective slashing and cutting although it certainly, as a spear, is meant to be used primarily in the thrust but tip cuts would also be effective.
There is also enough mass in the head that even a cut on maille would do some concussive damage in my opinion.
The wings are obviously designed to parry/block other spears and would also be very effective grabbing the edges of a shield or strip up an opponent behind the knees or any other body parts.
I also think it could double easily as a boar spear for hunting as the wide blade would do considerable damage and the wings would keep an angry wild boar from running up the shaft to get revenge. ( One could also say that this might keep a dying swordsman out of range before he passed out and died maybe ? Usually this aspect is only brought up for hunting dangerous game but keeping a vengeful and mortally wounded foe a few feet away for a few seconds does have it's merits I think ).
I will be mounting this myself using a white oak " BO " staff but I'm not sure yet if I will use a strait or tapering shaft.
Michael also supplied a mounting nail with the head of the nail ridged so as to match the ridgeline of the socket: To not damage this nail head I will tape a small piece of wood to the face of a hammer when I set the nail into the haft. and I will pre-drill a small hole for the nail so that it doesn't bend when being hammered into the very hard oak and to not stress or spilt the wood. ( A close fit to the inside diameter of the socket + just a little epoxy cement at the mouth of the socked + the nail should make for a secure fitting of the spearhead. Avoiding filling up the socket with epoxy is just so I can more easily replace the haft should it become necessary in the future ).
Well, I am extremely happy with this spearhead and it's really an opportunity I'm glad I didn't miss since the value for money spent is such that even at twice the price I would be still getting a bargain I think: I can't recommend Michael's work more highly as well as the excellent customer service. :D :cool:
P.S. The wooden box in came in is great for storage should one want to collect spearheads and not have them mounted as well it assures that damage in shipping would be close to impossible if one excludes nuclear attacks. ;) :p :lol:
