Posts: 643 Location: Minnesota, USA
Wed 12 Jan, 2011 11:21 am
Re: kidneydagger?
| Richard van der Mast wrote: |
| can someone tell me more |
You have quite a beautiful piece! Can you relate some information such as where you picked it up and any provenance (accurate or not) that came with it?
Thu 13 Jan, 2011 2:51 am
it came of the noth of the netherlands(friesland)
there was it found when a old house was broken
so ca you tell me from what period this might be?
gr ricard
Fri 14 Jan, 2011 12:23 am
isn't there anybody who can tell me more?
Posts: 367 Location: Seattle, WA
Fri 14 Jan, 2011 12:32 am
| isn't there anybody who can tell me more? |
Sometimes it takes some time for people to get back to a post. Some people only log in once or twice a week, or people have to go through their personal library of research books to find something.
It's a gorgeous piece! I hope someone can chime in with some ideas. It looks like the hilt is made of ivory? I would like that, I've been trying to collect images of ivory hilted daggers.
Posts: 1,734 Location: Oxford, UK
Fri 14 Jan, 2011 1:18 am
Well I think there are many things that are not quite right and taken together I suspect this is not what it seems.
The form is very unusual and I have not see one like it before.
The blade flaring before the hilt is unusual.
I would expect a dagger of this status to have a reinforced point
The hilt appears to be ivory, but is not approaching symmetrical or evenly formed and the spiral twist is rough and unevenly executed - I would expect if Ivory was used it would be better worked than this.
The brass work looks like it has been lifted off other objects and used for this application.
The pommel plate is of either a very high standard of fabrication or is modern cast whilst the rest of the brass work is crudely executed.
why it was made I do not know, but I think it was made within the last 100 years or so.
I hope this helps
Regards
Sat 15 Jan, 2011 5:04 am
Posts: 87 Location: Holland
Sat 15 Jan, 2011 7:03 am
Iam very sorry, but it looks to me that the dagger has been recently fabricated.
BTW. did you got it from somebody out of Nijmegen?
best,
Sat 15 Jan, 2011 8:11 am
no
i got this from someone out of friesland there it was found when a old house was get broken
Posts: 1,757 Location: Storvreta, Sweden
Sat 15 Jan, 2011 8:46 am
From the pictures, I do not think this is a medieval dagger.
It may be 19th century.
It could be made to be a "replica" at that time.
A few things points to this:
-The hilt seems to be "glued" together of various components. This is not a regular way to construct dagger hilts in the 14th century.
-The bronze or brass borders looks like they are cut from a running strip of repetitive rolled or stamped pattern. Not like they were shaped for the purpose. I get the impression that some one has taken the decorative border from some pice of furniture, and cut it so shape to fit this dagger hilt.
-The cap or pommel plate is glued on top of the end of the grip, with no visible riveting of the tang (this is very unusual and apart from preserved originals). It looks sort of OK if you do not look too hard or with a critical eye, but on closer observation, it stands out as very a-typical. It looks like some decorative boss taken from a lavish neo-gothic pice of furniture.
-The balls of the hilt look like they are also glued in place. Or it may be that the glue has filled the cut lines that mark the balls. Either way, it is most irregular and not at all like what you see on surviving originals.
-The whole cavity under the end band towards the blade is filled with this glue-stuff. Never seen such a construction on an original.
-The blade seems to have a midrib, but in one close up photo it is evident that one edge (at least) is blunt. Very blunt. I wonder if the blade has some strange sort of ricasso, or if it is single edged. The blade as a whole is rather badly defined. Not all originals are that carefully made, but they still look a lot ยด"sharper" and purposeful than this blade. To me the blade looks like it is made to *look like* a dagger, rather than to *be* a dagger.
I would look again at the story of the find place.
It may be that the story is true, but the dagger is very unlikely to be an authentic medieval dagger.
This is from seeing the photos. I cannot guarantee my impressions is the truth, but I would be *very* surprised to hear the dagger is a genuine antique from the medieval period.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
