Posts: 44 Location: Denmark
Fri 07 Jan, 2011 1:52 pm
Can anyone explaine this plate?
I just stumbled over this plate when i was looking through the Talhoffer Ambrasser Codex (anno 1459). Is there anyone who can explain to me just whats going on?
http://dl.dropbox.com/u/3814349/talhoffer.jpg
Anders :)
Attachment: 157.78 KB
Posts: 208 Location: Massachusetts, USA
Fri 07 Jan, 2011 2:13 pm
This is probably the crazy explanation but here goes:
Talhoffer is showing off his creativity by illustrating that a perfectly ordinary crossbow can in fact be used to save a man drowning in a river or fallen off a ship. The three men are demonstrating this technique for the reader.
As depicted, the shooter has just fired his blunt, padded bolt past the man in the water, placing a heavy line within his reach so he can be saved. The shooter's assistant has a knife, to cut the line in a hurry so it can be retied to another bolt and launched again if the first man missed. He also has a cup of wine or brandy for immediate medical application after the rescue.
Posts: 159 Location: Nøtterøy, Norway
Fri 07 Jan, 2011 2:18 pm
They could also have had the wine first ;-)
Posts: 936 Location: WV
Fri 07 Jan, 2011 7:09 pm
didn't Talhoffer know it's illegal to kill prey in the water! hehehe
Sat 08 Jan, 2011 2:40 am
| Dan P wrote: |
As depicted, the shooter has just fired his blunt, padded bolt past the man in the water, placing a heavy line within his reach so he can be saved. The shooter's assistant has a knife, to cut the line in a hurry so it can be retied to another bolt and launched again if the first man missed. He also has a cup of wine or brandy for immediate medical application after the rescue. |
I was thinking something similar, but it just seems like a weird way to show it. Especially since a text would have explained the technique better than several steps drawn in one picture.
Posts: 104 Location: Brittany
Sat 08 Jan, 2011 4:22 am
Hi
I was thinking of sending a rope across the river so the soldiers can cross it safely (still used nowadays) but you must be right : I didn't notice the brandy :D
Posts: 238 Location: Vancouver Canada
Sat 08 Jan, 2011 12:51 pm
I vote for Yet another fun Medieval early Renaissance Drinking Game.
Let me make up some rules for this game best played in the heart of Winter
1: Chip a hole in the ice & stake a rope across the hole
2: One player strips and the tight-rope walks across hole
3: His friend takes shots at him with a blunted cross-bow attempting to knock him off the rope
- Note: the rope is tied to the quarrel because quarrels cost money
4: If he first man makes to the other-side he gets to drink the whole glass of hot mulled wine, but if he is knocked senseless the crossbow man splits the glass with the man holding the wine.
-Note: the guy holding the wine uses a knife because its 1470ish and everybody has a knife. Don't you hold your glass with a knife?
5: They each take turns crossing the hole until someone dies of hypotherma
mackenzie
Posts: 307 Location: Ottawa, Canada
Sat 08 Jan, 2011 2:44 pm
I've heard an interpretation that there are two separate things going on here; The use of the crossbow to rescue someone in the water, and applying poison to a knife. IIRC, a nearby page shows a man mixing something in a container that might be medicine or poison.
I'm not sure about any of it, but I suspect Talhoffer originally intended to add captions to some of these images.
Posts: 8,310 Location: Montreal,Quebec,Canada
Sat 08 Jan, 2011 4:40 pm
A) Man in the water wins if he can swim to the other side on the pond.
B) Man with crossbow wins if he can knock out the swimmer with the blunted crossbow bolt.
C) Man with knife cuts throath of the loser ??? Gives someone a good shave later. :confused: :lol:
Posts: 409 Location: Anchorage, Alaska
Sat 08 Jan, 2011 5:14 pm
Proof that Lysergic acid diethylamide was first uncovered in the 14th century.
Sat 08 Jan, 2011 5:22 pm
Hi Anders, I'm sure you already know that this segment of Talhoffer comes from Conrad Kyeser's book on siege engines, pyrotechnics and other secrets called Bellifortis. I also think that the plate is showing two entirely different things to save space.
Getting a rope across a body of water using a crossbow seems like a very reasonable explanation for the first half of the image. But I have no clue what the guy with the dagger is doing. :\
Sun 09 Jan, 2011 3:47 am
Thanks for the many amusing interpretations guys! :D
| James Head wrote: |
Getting a rope across a body of water using a crossbow seems like a very reasonable explanation for the first half of the image. But I have no clue what the guy with the dagger is doing. :\ |
Actually i Didn't know that. :) Thanks a lot!
I think your partially right in that Talhoffer is trying to save space. I don't however think that the image shows different things entirely, as I find it more likely that the plate shows a sequence rather than different things.
The interpretation of a man trying to get rope to a drowning man is correct, in my opinion. But I don't understand the Rope the man clings to. I guess it shows the intention of shooting the rope out. What I cant figure out is why the rope is tied to poles, and especially on the other side of the water. What's the point if your trying to save him?
The man with the glass confuses me completely.
Sun 09 Jan, 2011 10:09 am
| Anders Kramer wrote: |
| The man with the glass confuses me completely. |
it looks like he's trying to find an angle over the horizontal (water surface of the glass) using the blade as a sight. (sounds silly? :blush: )
If those pages concern artillery and engineering it could make sense.
Sun 09 Jan, 2011 11:16 am
The interpretation of a man trying to get rope to a drowning man is correct, in my opinion. But I don't understand the Rope the man clings to. I guess it shows the intention of shooting the rope out. What I cant figure out is why the rope is tied to poles, and especially on the other side of the water. What's the point if your trying to save him? |
I don't think it is a rescue as much as a crossing. Imagine a spy has returned from his mission and is on the other side of the river. Both he and the crossbowman would be able to stick poles into the banks of the river. After the bolt and rope had been shot over, the lone man would tie the rope to his pole, take off his clothes, perhaps send them over first, and then cross the river.
Sun 09 Jan, 2011 1:37 pm
| James Head wrote: |
I don't think it is a rescue as much as a crossing. Imagine a spy has returned from his mission and is on the other side of the river. Both he and the crossbowman would be able to stick poles into the banks of the river. After the bolt and rope had been shot over, the lone man would tie the rope to his pole, take off his clothes, perhaps send them over first, and then cross the river. |
But why would he need to out a pole in the ground? Wouldn't one on the side with the crossbow be enough (if any)?
@ Stephane; Sounds plausible, but it doesn't seem to involve artillery.
Posts: 249 Location: Whitewater, Wisconsin USA
Sun 09 Jan, 2011 3:06 pm
Anders what site is that plate from? Maybe seeing the plates previous to and after would help. Of course I don't know if the nearby plates are related.
I showed this to my parents, and they seem to think its some sort of medical treatment, their conclusions are:
1) He's in the water because he has a fever.
2) The guy with the knife and cup is going to bleed him.
3) no explanation for the crossbow...
But then again wouldn't at least the guy with the knife be wearing physicians clothes/hat?
My dad also seems to think there is some kind of symbolism with the guy having the knife in his mouth, but since it's a manuel trying to teach, why have symbolism that would just make it less understandable?
I don't know...maybe talhoffer/talhoffer's artist got drunk in the middle of drawing a picture on how to get a rope across a pond... :p
Posts: 643 Location: Minnesota, USA
Sun 09 Jan, 2011 4:24 pm
Personally, I think David's theory of LSD remains in first place.
Mon 10 Jan, 2011 12:27 am
Hi,
LSD, yes, maybe some contaminated rye bread :D
The answer could be in the text on the previous pages, could anyone here read it?
http://www.kb.dk/da/nb/materialer/haandskrift...2_290.html
(our plate is on Page 30)
Mon 10 Jan, 2011 3:47 am
According to the webpage, the images are neither part of the Fechtbuch by Talhoffer nor the Bellifortis by Kyeser. The section is listed as Bildkatalog, catalogue of pictures, on the browsing list left side of the webpage.
Accordingly, the first bit of written text on a previous page is found on 24 and is the last part of Talhoffers Fechtbuch, dealing with judical duels and the aftermath. The next bit of text on a following page, on 34 is already part of the Bellifortis and deals with the war chariot depicted on the same page.
Interestingly, a similar vessel like the one the man with the knife is holding, can be seen on the previous page being destroyed by a man with a club. But honestly, I have no idea what these pictures could mean.
There are lots of strange pictures in this codex, f.e. on page 26 were you can argue that a man gets a tattoo.
Or the lawn-mower-of-death on page 48! :D
Mon 10 Jan, 2011 4:38 am
A pdf of the full manuscript and a translation by Jeffry Hull is available
HERE. He includes comments on possible interpretations of the images, which is where I previously heard the poisoned knife theory.
I currently like the theory that the knife is being used for a sight line off the level surface of the water in the cup. My guess is that he's holding it in his mouth either as a set reference point for a specific known angle, or to steady the end of the knife, or both.
Perhaps this is an early stage of building some sort of bridge and they are looking for a place where the opposite bank is relatively level with the near bank?
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
