"...A fuller runs most of the length of the blade, tapering in width along the blade's length. Where the spine changes to the false edge the fuller is interrupted, rising up and actually becoming thicker than the blade before resuming its run toward the point. While I'm not exactly sure of the purpose of this feature, it is present on the original and is visually interesting...."
The fuller of the original seems not as deep as on this sabre. It is covered with a goldened cupper strip on both sides.The fuller is not interrupted. Only the cupper strip is rising up from the blade's surface. It seems the blade had been bent for some reason, and the corrector couldn't flat the strip into the original lay.
A very interesting explanation for this could give the "Hojnovskij" sabre form Kiev. It was found bent in a stone sarcophagus.
I got somewhere a photo from the golden cupper stripe.
Zoltán
