Mrak E.Smith wrote: |
it's an amazing topic, unfortunately the pics are unavailable now.
Can someone fix it? Here's my gratitude :D |
Hi Mrak,
They're available...you may have opened the message during some server trouble I was having recently.
Luka Borscak wrote: |
Michael's later test showed that XIII and XIIIa swords are effective against textile defences with tip cuts. Rounded sharp tips cut well that way. I don't have much experience but I would say that such cuts are draw cuts and sharp rounded tip does in a draw cut what katana's curvature does in a "normal" cut. More experienced people, correct me if I'm wrong. |
Shawn Henthorn wrote: |
The theory was also put forward that the lack of an iron or mild core and more of a "spring temper" in the blade could have reduced effectiveness due to the vibrations |
Taylor Ellis wrote: |
The problem I have with the temper theory is that there are many accounts of a blade's flexibility being a desirable attribute. |
Michael Edelson wrote: |
I did not bother with the poleaxe against the jack, it would not have penetrated. Maybe the 10 layer, but not the others. But then it doesn't have to, not to pulverize the man underneath. ...t. |
Daniel de Castro Caputo wrote: |
...... I dressed a mail shirt once, and i haven't felt secure inside this armour, felt like someone with a barbecue espeto could kill me easily...
Raino S wrote: |
this stuff is fantastic reference :D.
although i noticed that the rings were all riveted. this is historically true for some mails, however, i was browsing around on hurstwic.com, specifically this page: http://www.hurstwic.org/history/articles/manu...g_mail.htm and one particular part really struck me. they had done studies on the grain of the rings, and they found out this: [ Linked Image ] the grain of the whole rings did not follow the shape of the ring, but instead has a a grain structure that suggests the rings were punched out of sheet metal. now i'm curious how a ringmail of this type would stand up to the same attacks as the ones in this thread, compared to other types of ringmail. |
Jesse Eaton wrote: |
BTW you can just call it 'mail'. Terms like 'ring mail' and 'chain mail' are redundant. Mail armor is always made of rings linked together like chains. |
Seeing this thread revived reminded me of the tests I wanted to see. If anyone out there would be so obliged as to test the cuts thrusts and slashes from arrows and swords against all three layers (i.e. 1 layer padded, one layer mail and one layer 30 layer linen) I'm sure we would all appreciate it. I have yet to see this test performed and I think that a lot of the speculation about mail would be well tested this way. If the mail could be put on an impact dummy, that would be even better:) |
William P wrote: |
however regarding the earlier maile, it was mentioned it was very difficult to compromise even with a lance thrust. i findthat strange, because it has been mentioned and suggested by multiple sources that it was the crouched lance 's power that suurred on the use of plate |
Quote: |
, as the energy was too greatfr maile to resist.and this is indicated by the dichotom of the style of fighting when comparing eastern cavelry and western knights, with ottoman and egyptian cavelry having plates in very sparse areas (from the book weapons and fighting techniques of the medieval warrior)
its also mentioned as shown being teted in the series 'weapomnns tthat made britain their segment on armour evolution thelongow and especially the knights lance |
Jean Henri Chandler wrote: |
On cutting swords vs. mail armor.... keep in mind, in this period, not only was mail armor rare compared to the amount of armor in some later Medieval battlefields, but it didn't cover the whole body. Most people here in this list don't have to be reminded of the forensic analysis which has been done at battlefields like Wisby, most skeletons with evidence of cuts were cut on the lower legs (lower left leg particularly IIRC). A hauberk doesn't protect the lower legs. Or the lower arms in most cases or the face or in many cases the neck. In fact the most common type of mail from Classical times through the Dark Ages was probably one or another type of short byrnie or corslet which really only protected the torso, and the only other protection commonly worn was a helmet protecting the top of the head, more rarely with a coif or an aventail or even some face defense ala sutton hoo. These areas offer good protection against most attacks when using a shield, but by and large I susepect that the short answer is:
They defeated that armor by cutting around it. Note that it's the rise of head-to-toe mail armor during the Crusades period which seems to coincide with the rapid evolution of pole arms and poll-axes (early examples being that large two-handed huskarl axe in England which showed up as armor was becomming more widespread) and heavier crossbows and the early two handed swords, which seem to have predated plate armor |
