Posts: 33 Location: Washington
Thu 25 Mar, 2010 3:59 pm
16th century tasset construction
I always wondered:
Are the lames on the "inner" thigh attached to each other the same way as the ones on the "outer" thigh?
If so, are the leather strips used only as reinforcement?
Thank you in advance
Attachment: 79.96 KB
rivet heads on the outside of the lames [ Download ]
Attachment: 83.75 KB
inside showing leather strips [ Download ]
Posts: 1,563 Location: Upstate NY
Thu 25 Mar, 2010 4:29 pm
Lucas, the outside edge is most always on sliding rivets rather than leathers as the need for compression is on the inside and center of the thigh rather than the outside of the thigh.
Posts: 64 Location: Auburn, NY USA
Thu 25 Mar, 2010 4:59 pm
What Allan said and if you want to build them like your life depends on them, a backup strap in the center.
Attachment: 91.66 KB
Fri 26 Mar, 2010 4:40 am
Another note Lucas, the rivest you've highlighted in the first pic are actually blind ( they are not through both plates, they are not attaching anything they're just filling a whole ) and not the rivets holding the straps in which would be flush riveted on the underlap of each plate. Blind rivets are either a) filling a hole that was needed while building to make the plates match up in terms of shape, but not necessary for ariculation b) simply to maintain symetry between the outside edge, which will most always have an articulating rivet, and the inside edge which deosn't need them c) occasionally to fill in holes mistakenly located. In this case as the cuvre is not sever B would propabaly be the case.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
