Hello,
I made this messer.
The messer are made from sprig steel and hardening 50-52 Hrc.
Start material - thick - 0.8cm
Total length - 83.5cm
Length of blade - 64.5cm
Handle - 18 cm
Width of blade at the crooss quard - 4 cm
Length of cross quard - 18cm
Weight - 1000g
All Best Stanislav
www.Mac-armour.cz
mac_platenik@volny.cz
Attachment: 44.96 KB
Attachment: 52.18 KB
Attachment: 35.55 KB
Attachment: 39.16 KB
Attachment: 58.14 KB
Attachment: 79.44 KB
Ahoj Stanislav
Very, very nice! Is it sharp? Can you give the point of balance? What about sheath?
Nice looking bit of work there.
Sa'ar Nudel wrote: |
Ahoj Stanislav
Very, very nice! Is it sharp? Can you give the point of balance? What about sheath? |
Hello,
many thanks)!
This messer are not sharp. This messer are for training. The edge thickness is 0.2mm.
The balance point is 8.5cmm from cross quard.
All best Stanisalv
Hi Stanislav ! Very nice messers you made. :)
0.2mm at the edge seems a bit thin for pieces dedicated to training... Do you mean 2mm ?
Hi
Very nice job!
I have one question in mind for some time ... is the rivets on the handle are hollow or that little hole on them are only in surface? ...And Hugo is right, 0.2 mm is almost sharp!!
Thanks
Dan
Very nice job!
Thanks
Dan
The pair is very good looking and the stats are great. I guess the edge is 2mm, as Stanislav said, it is not sharp and meant for drilling. 0.2mm is dangerously sharp!
I would love to see one with stag grip and proper sheath.
Hugo Voisine wrote: |
0.2mm at the edge seems a bit thin for pieces dedicated to training... Do you mean 2mm ? |
Hello,
I am very apologize - many work this week((
yes, I mean 2mm))
D. Besnier wrote: |
Hi
Very nice job! I have one question in mind for some time ... is the rivets on the handle are hollow or that little hole on them are only in surface? ...And Hugo is right, 0.2 mm is almost sharp!! Thanks Dan |
On the handle are tubes.. The tube is dilated from both side.
I would love to see one with stag grip and proper sheath. |
Yes, it is true - 2.0mm))
I do not made the scrabbard, the client did not want it.
I believe there would be a market in Europe and the USA for Messer training blunt like this . Very nicely done!
I agree... and for a sharp like that. Any photos with people in them for scale?
J
J
