For years now I have been wanting to make a ballestrino and now is the time.
I love making crossbows and these particular type have fascinated me for a number of reasons and I could prattle on for hours...............
Ballestrinos were small, powerful crossbows commonly called 'assassins bows' that were popular in Italy and Spain in the 15th and 16th centuries. I am not quite sure what they were for and my particular opinion is that they were either executive toys or self defence weapons but personally don't believe they were for assassins as a trade group as such, although I guess they could have been used for this.
The bows are clearly very powerful, though with a short powerstroke they won't deliver what a full size bow would. This particular bow has been tested at 320lb at 44mm (1 3/4"). I have wondered how powerful they were and now I know, though this is perhaps not as powerful as some. There are very few of these bows existing and the only one I know vaguely near to me is one in RA at Leeds; all the ones I know about have very different trigger systems and are visually quite different. I think that there were not enough of them made to fall into standard patterns which explains the variety of styles. They all have a common layout in that they have a trigger block that slides forward and engages the string and then is drawn back using the inbuilt screw in the handle.
I have also wondered what they shoot. There is a lot of power in this bow, but the powerstroke is short, is it for playing or for defence?. In a nutshell I cannot make up my mind. The one in the RA has a groove so you can see the approximate diameter of the bolt and I estimate no more than 6mm. This bolt could be of normal construction but would weigh about 6 or 7 grams (1/4 oz) but as steel bows have a maximum return rate that is quite low the bolt would neither have much impact energy or velocity but an all steel bolt would have the impact energy and most of the velocity so that is where I am leaning at present. I don't know of any bolts for these in existance.
Most of these bows are extensively decorated, etched, gilded, inlayed etc but some were more utilitarian. The one at the RA is particularly utility. It looks like it was machined and the trigger block is stuck on top in a rather ugly manner and to top it all it looks just like an industrial micro switch, complete with a slot head screw, but some of the expensive ones simply had a wing nut to load them which is pretty crude too.
I have decided that this lack of standardisation and extant examples allows me a little freedom to make something I would like to make.
Any way the intro essay is now over but hopefully this will allow me to answer a few questions I have been wondering about.
The bow started life at 8mm thick this was just too much for me so I took it down to 6mm and it is 220mm nock to knock. The trigger priciple is the same as the one at the RA, but I reconfigured it so that it sits withing the bow body rather than above it which will make the appearance neater and less industrial and to my eyes less modern.
I have made the trigger mechanism and started the body and integrated the screw.
I hope it intrigues you as much as does me.
