I have always wanted to own a sword, and finally found one I could afford at an antique shop last weekend. It is very rough and has been much abused by previous owners. It is marked Mansfield & Lamb, 1862, and was apparently once plated (now rust covered and plating is almost all flaked off). To make things worse, the point of the blade has been rounded off (now about 34 1/2 inches long) and a HOLE has been put in the tip and another in the top of the hilt for hanging!
There was no scabbard with the sword. The hilt appears to be brass (non-magnetic) and is also plated and pitted badly. The wooden handle has been painted, apparently white and then later black, and the wire (which IS magnetic and therefore not brass) has been removed except for about a quarter of an inch at one end. The pommel is not fastened to the tang which is threaded at the end. There was no nut of any kind with it when I bought it.
My main question is: How was the tang originally fastened to the pommel? Pictures I've seen seem to show the hole in the back of the pommel leaded over. Should there be a nut somewhere to hold the handle, hilt, and pommel to the tang (and blade)? And finally, is there any chance that my sword is original?
Sorry about the focus...the end of the tang is threaded.
(I have added the leather.)
