english terminology
Hello all together,
I am looking for the english word for "Waffenkunde" (it is german), may be to explain with: doctrine of weapons.
And also "Blankwaffenkunde" ( it is german), may be to explain with: doctrine of edged weapons.
I don't find the terms in conventionally dictionary.
kind regards
Hallo
Waffenkunde is Wearponscience and Blankwaffenkunde is (like Cold or Sharpwearponscience ?) Arme blance science.
Small specification Blankwaffenkunde is about cuttin and sting wearpons science (sword, rapier.. for exampel)
Waffenkunde is science about fire wearpons and cuttin and sting wearpons.
Much thanks to you,
but isn't it then "Weaponscience" instead of "Wearponscience" ? Surely a typos?!
kind regards and nice weekend
"Hoplology" might be the nearest English term.
http://en.wikipedia.org/wiki/Hoplology
hoplology seems to be the science of fighting, focused on the human, while waffenkunde is the knowledge of or sience of weapons, focused at the object. (something more like "weaponology", if we were to make up our own words)
Thank you all together again,
Audun, what you explain is correct. Is weaponscience the correct term? Or is there at all a special english term for "Waffenkunde".
kind regards
hoplology and edged weapons
Sean, Sabine & Andun
the hoplology reference has more to do with the mind set, or psychology, of those involved with the fighting, the word, or words, they are looking for has more to do with the weapons themselves.
The ''blank'' reference in german has been translated into french as '' armes blanches'', which in turn would be '' edged weapons'' in english, including everything from knives through swords to pole arms...anything you will cut or stab with when involved in attack or defense.
In french we would not really favor the use of only one word as the french language favors the descriptive process, so the
blankwaffenkunde would end up as '' L'étude des Armes Blanches'' ( étude= study of). or alternatively ''La Science des armes Blanches'' ( in this context 'science' = knowledge, though the simpler french equivalent would be 'connaissance' instead of 'science', this latter term having a more empirical connotation to it)...
I would think that the english would also favor a descriptive assembly of words over a single word, such as The Study of Edged Weapons, or The Science of Edged Weapons...I would prefer 'study of' as being less presumptuous than ' science of ',
which seems a bit to definitive in its scope.
Good luck with the translation, most of us are still working on '' weltenschaung''...
M. Hudon is correct about English's lack of smashingwordstogether...bit a joke there, that's not really a word. German seems to have a fondness for combining multiple words into a single word, whereas English leaves the words separate as a phrase. If you're intent on a single word translation, "swordsmanship" might be close.
Thank you all for help.
I am going to circumscribe "Waffenkunde" in the mind "Science of weapons".
"German seems to have a fondness for combining multiple words into a single word, whereas English leaves the words separate as a phrase." Yes, this is surley correct.
kind regards
I'm almost tempted to coin a term like "Wapenken" or "Swordken" for this kind of thing.
I learned something interesting today. I have not verified it but I was told by a knowledgeable person that the tern "claymore" just means "sword" in Gaelic. This was a source of confusion fro me because I have heard both two-handed monsters and single handed broadswords referred to as Claymore. I was told today the Claymore does not refer to a style of sword at all.
I am hoping to get some verification on this. Thanks.
Generally, you are correct; however, it is a somewhat involved question of Celtic terminology/vocabulary. I suspect that it wouldn't be too hard to find online, but I'm sure that Chris Thompson of the Cateran Society can answer this clearly and unambiguously.
Steve
Thanks Steven. I will follow that lead.
Edit::
Websearching brought up the following:
It would appear that Claymore does just mean sword.
With regard to the large two-handers the full name seems to be "claidheamh da laimh".
dà = two, làmh = hand
This comes out to "Claymore Two Hand".
broadsword: claidheamh mor
backsword : claidheamh cuil
basket-hilt sabre: claidheam crom
http://www.electricscotland.com/familytree/ma...aymore.htm
Some have suggested "spathology" for the study of swords, but that doesn't cover all weapons. I think "weapon science" is reasonable choice, even if it is a new term. Most people will understand what it means.
