(Hopefully my picture will show up below along with some other viking items in my collection).
I think that the Windlass / MRL description of this sword is pretty accurate; it's a basic looking sword, no frills past the fact of the fairly standard lobated pommel. It is classic in its look, profile, and overall dimensions, and I would say is essentially representative of several historical examples other than minor details of construction.
Some Stats:
Overall 36.5 inches.
Blade 30.5 inches.
Feels like 2.5 pounds.
Grip 4 inches.
PoB - 5 3/4 inches.
This sword has a very solid, business-like feel to it without being overly heavy or sluggish. In fact it handles quite well - in my opinion with the right balance of blade presence and 'wieldability' for a sword of this period. The blade is a strong point - it has slight but even profile taper with a similarly tapering, medium-wide fuller in the classic Viking pattern. It can flex, but it is stiffer than most of their other viking models (e.g., Sticklestad, Ulfberht etc). The reason seems to be that the blade is slightly thicker than those other models, without being overly heavy. It does not have the sophisticated blade geometry of more expensive models (i.e., not much of a distal taper in thickness until near the end), but in terms of handling, seems to get by without this. Overall, a good compromise between strength, weight, and balance.
I have not tried to cut anything with it yet (and my model is not sharpened), but I am guessing that it will compare favorably to other models in this class. This guess is based on the blade geometry and harmonics, which seem decent for a sword in this class. Overall it is not especially prone to vibration, and the nodal points are close to where they should be. (Mind that I am comparing this to similarly priced swords).
The grip is a little longer than average for Viking swords, but within historical limits. It is just long enough to use a hammer grip for those who do not like the handshake grip. This is facilitated by the outward curving upper and lower guard, which make holding this sword comfortable compared to many viking types. It also works fine with a handshake grip, or transitioning between the two grips. The rounded rectangular grip provides good control, and the leather of the grip is smooth but not slippery. Some won't like the protruding stitching - it doesn't bother me.
Overall the finishing is quite good. Without looking down the blade toward a light, grind marks are generally not visible and the fuller is quite even for its full length. The ground-out and polished lobes of the pommel are not sophisticated, but OK. The pommel appears to be peened on but the peen is barely visible. Interestingly there is a tiny 'riccasso' buried within the slot where the blade joins the cross. I have not seen this before but saw it on another new Windlass model...I wonder if this is supposed to improve strength at the joint. My understanding is that these 'built up shoulders' appeared in earlier iron age swords and later renaiscence swords, but should not appear on Viking swords. However, you have to look for it to see it, so it's no big deal. Similarly, the pommel is in one piece whereas I think that most historical swords of this type would have a pommel attached to an upper guard, but this is splitting hairs on a sword in this range.
So far the hilt is tightly assembled with no loose fittings, but only time will tell....
All that is just reporting, as accurate as I can be. The real reason I am writing this is because, although this is not an exciting looking sword, it is rapidly growing on me. It has that solid functional feel that makes you appreciate its simple appearance the more you use it. I'm really happy I bought this sword and (at this point in time) feel confident to recommend this to anyone on a budget looking for a decent viking replica. It's a good sword for the money! (I'm a pretty critical guy, so that's about as enthusiastic as I get).
In this sense, this sword reminds me a lot of the Windlass Type XIV - kind of a plain Jane at first glance, but earns its own reputation in time. I think they got this one right and I hope that they will keep making them for a while.
Disclaimer: there are always variations in the hand-made items from this manufacturer...the next one down the line may not be as good, so one needs to take a close look at each one.
- JD
Windlass 5-lobe Viking pictured with Valentine Armory Spangenhelm and Beowulf & Grendel Shield
