I have a friend looking to purchase a two-handed sword for test cutting. He is currently looking at a Lutel English Two-Hander, it is 150 cm overall with a 110 cm blade. I am just wondering if anyone has tried this particular model? I have searched the forums and it seems no-one has brought anything up about this model yet. It seems that Lutel makes very good quality pieces, however, this piece seems unusually cheap, making me slightly suspicious.
You can find it at the bottom of the "Two Handed Swords" section in the Lutel catalog.
I suspect the cost may be a bit lower than some others because the sword in question does not look particularly complex. although I'm not familiar with it, I would be surprised if its not up to their normal product standard.
I have a Lutel Zweihander. The quality is good. They don't usually sharpen their swords from what I understand. Expect a secondary bevel. My zweihander is sharpened, it has a secondary bevel, but the nice thing about the bevel is that yhey take the time to round of the bevel so that it smooothly flows into the edge.
Thanks for the replies, my friend definitely will be looking into getting this sword. Personally, I am thinking of ordering Lutel's Two-Handed Saber. However, I must admit, some of Pavel Moc's stuff also looks very good, like their hand and a half Embleton model. I am still trying to decide which one to get.
Flip a coin and decide how long you can stand to wait. Either route there is going to be some delay. Lutel is good about posting where they are in their work list on their website. Probably have to contact Moc directly to get an idea.
First of all, I must say that I am a big fan of LUTEL and Pavel Moc, owing and using their blunt swords for steel to steel training. I have Moc's Embleton and Durer, both are very good training devices.
Last February I participated in six-hour cutting seminar held at Guy Windsor's salle in Helsinki. There was a lot of sharp weapons available for test cutting, e.g. Albion Crecy and Agincourt, several custom weapons by JT Pälikkö, Arms& Armor Katzbalger and Milanese rapier and some sharp czech swords. We had enough time and wet mats and I used the opportunity to cut with everything I was alowed to (some custom swords worth 2500 euro or more were not offered to ordinary students).
My experience: Best cutters proved Albion swords and custom blades. A&A swords worked fine, although neither katzbalger nor rapier are designed for cutting. Czech swords failed.
Now I completely agree with Peter Johnsson, who once wrote in a thread of this forum that a sharpened blunt sword is not the same thing as a sword MADE sharp, I am talking about my favorite czech swords now, gentelmen.
My message: DON'T SAVE ON SWORDS. I have ordered Albion Maximillian from Albion Europe..
Konstantin Tsvetkov wrote: |
Last February I participated in six-hour cutting seminar held at Guy Windsor's salle in Helsinki. There was a lot of sharp weapons available for test cutting, e.g. Albion Crecy and Agincourt, several custom weapons by JT Pälikkö, Arms& Armor Katzbalger and Milanese rapier and some sharp czech swords. We had enough time and wet mats and I used the opportunity to cut with everything I was alowed to (some custom swords worth 2500 euro or more were not offered to ordinary students). My experience: Best cutters proved Albion swords and custom blades. A&A swords worked fine, although neither katzbalger nor rapier are designed for cutting. Czech swords failed. Now I completely agree with Peter Johnsson, who once wrote in a thread of this forum that a sharpened blunt sword is not the same thing as a sword MADE sharp, I am talking about my favorite czech swords now, gentelmen. My message: DON'T SAVE ON SWORDS. I have ordered Albion Maximillian from Albion Europe.. |
In that case, are there any other companies besides Albion that make "appropriate" sharp swords, as opposed to sharpened blunts? Also, how bad can sharpened blunts be? Are they just a little bit worse than a sharp? Or are they a lot worse?
Angus Trim swords are well respected for cutting ability, his blades are based more on established perfomance parameters than exactly re-creating historical designs. Some collectors prefer a more historical look but for performance for dollar I think they are hard to beat.
A blunt sword will usually have a fairly thick edge that requires a drastic secondary bevel to acheive a decently sharp edge, unless one is willing to sharpen along the whole width of the main bevel, which amounts to re-grinding the blade.
A good cutting sword for soft to moderate targets, in my opinion, should have the main bevel ground until the edge is no more than .020", before sharpening. This pretty much requires that the blade be hard enough to support this thin material through the stresses of cutting, or you end up with a folded or rolled edge. Opinions on this will vary a great deal and not all original cutting swords have the same geometry anyway, so there is plenty of room for interpretation.
Justin King wrote: |
A blunt sword will usually have a fairly thick edge that requires a drastic secondary bevel to acheive a decently sharp edge, unless one is willing to sharpen along the whole width of the main bevel, which amounts to re-grinding the blade. A good cutting sword for soft to moderate targets, in my opinion, should have the main bevel ground until the edge is no more than .020", before sharpening. This pretty much requires that the blade be hard enough to support this thin material through the stresses of cutting, or you end up with a folded or rolled edge. Opinions on this will vary a great deal and not all original cutting swords have the same geometry anyway, so there is plenty of room for interpretation. |
I did look at Angus Trim, but he doesn't seem to list the prices for most of his stuff, which means I am not sure about which models are cheapest. I am currently looking for a good mid-range sword don't want to go much beyond $300 U.S. Ideally, I want to stay around $250.
Sam N. wrote: |
In that case, are there any other companies besides Albion that make "appropriate" sharp swords, as opposed to sharpened blunts? Also, how bad can sharpened blunts be? Are they just a little bit worse than a sharp? Or are they a lot worse? |
I am currently working on a matched set of blunts and sharps for Guy Windsor. The sharps will look like the blunts at a distance, and handle similarly, but there is quite a bit of difference at the edge..........
The sharps will be as good a cutting sword as anyone today makes for the "type". And the blunts will be decent training blunts. But said blunts would have to be ground into totally different blade shapes to make decent cutting swords......
In other words, you can cut with a sharpened blunt. But it won't be the same as cutting with a sword meant as a sharp by a quality maker from the get go.........
ATrim's stock seems to move pretty fast so you would probably have to contact him directly to get current availibility and pricing. His swords may be a bit above your price range new, it may be worth watching the second hand market if you are particularly interested in one, they do pop up frequently.
Unfortunately under 300$ limits your choices quite a bit and puts you into the "hit and miss" quality range. I would suggest doing as much research as you can before buying since some of the lower priced swords are satisfactory for cutting but I think many more are not. Given some of the quality-related issues that I have read about on the forums recently (some of which have involved serious injuries to the users/bystanders), I am reluctant to make a reccomendation beyond doing your homework and being careful no matter what you get. An ounce of prevention is worth a lot more than a pound of cure when it comes to "playing" with sharp swords.
I did look at Angus Trim, but he doesn't seem to list the prices for most of his stuff, which means I am not sure about which models are cheapest. I am currently looking for a good mid-range sword don't want to go much beyond $300 U.S. Ideally, I want to stay around $250.[/quote]
Please, learn from my mistakes. If you by a 250$ sword now, you will buy another, worth 350$ in six month and finally get a really good sword cost 750$ in a year, but then you already have 600$ invested in blades you don't want. If swordsmanship is really important thing in your life, you most certainly can save the sum needed to buy a decent sword. I believe you can afford an Albion squire line or an A.Trim.
I have a sharp Embleton for you, if you still want it, but with no return.
I have a sharp Embleton for you, if you still want it, but with no return. |
You sound as if I am about to make a deal with the Devil :p . Seriously, I swear your quote there is one of the wisest things I have heard on the internet :cool:.
That being said, you have brought up a very, very good point. A point which I shall no doubt lose some sleep over.
I ask you, how much would this Embleton cost? I have now started looking at Atrim and they seem to be in the $450 U.S. range. Truth is, I am about to head off to university (yes, I am fairly young) and so I am not looking to spend that much money, I just need a fairly reliable sword that will cut through most mediums used for test-cutting. When I looked at the Embleton, it seemed perfect, made by a reliable company and in terms of of measurements: 11 inch handle, 35 inch blade. The only problem: It's made as a blunt. However, if this problem isn't too great, then I would be more then happy to own an Embleton. I have done a lot of my homework and have been asking around on many forums, yet it still seems that I can't find anything cheap enough without it being a completely useless piece of iron. Finally I have one last conflict, either your Embleton or a cheap Atrim, which is why I would like to know how much this Embleton would cost me.
Sam N. wrote: |
Opinions vary wildly depending largely on what each person wants to use them for.
Honestly, I think what you are calling a mistake is part of the learning process. Almost everyone does it, and many of us consider it a fond part of the process of earning knowledge and experience sooner or later. I've heard it said that you don't buy things, you by experiences. If there is any truth to that, I suspect you might someday change your opinion about your mistake as well.
If you want a Lutel now, contact Art Elwell of www.a-work-of-art.net. He normally has some lutels in stock.
Vay Duong wrote: |
If you want a Lutel now, contact Art Elwell of www.a-work-of-art.net. He normally has some lutels in stock. |
He doesn't seem to have anything but Del Tins on his website.
Sam N. wrote: |
He doesn't seem to have anything but Del Tins on his website. |
Art's website is years out of date. He carries more than what the website shows.
You can contact him via PM on this site or the email address on his website.
I did look at Angus Trim, but he doesn't seem to list the prices for most of his stuff, which means I am not sure about which models are cheapest. I am currently looking for a good mid-range sword don't want to go much beyond $300 U.S. Ideally, I want to stay around $250. |
I have a sharp Embleton for you, if you still want it, but with no return.[/quote]
I too would like to second Konstantin on this issue as well. The best policy is to save your money and buy simply the best blade you can get, not anything in a "price range." I myself probably "wasted" a good chunk of money on a $300 sword as my first buy and within a year I was looking to upgrade to a better weapon. That next one didn't suffice (Del Tin 2160), so I again bought a new sword (Lutel hand and a half) for $600 as a training weapon (unsharpened), and I'm very happy I did...but I am sad that I wasted over $800 on the other two swords that I wasn't happy about.
Now I don't even bother going by price on my purchases. IF I can get the money together I buy very good swords for a lot of money. If I don't have the money or I need it elsewhere...well then I don't buy a sword. My last three purchases have all been for over $1200 each with their scabbards (in one cast $2000 when I finally get the scabbard and sword back). Despite the prices I am VERY HAPPY with these swords and I cannot even imagine buying any cheap swords again.
So save your money, do your research on what you really want to get, and get it when you have saved up for the purchase. Then of course you have to wait...but that's another issue for another thread. ;-)
Page 1 of 2
