This is something that's been bugging me for a while.
How fast does a crossbow bolt travel in Feet Per Second if the pistol crossbow has a 50 lb. draw weight?
When I calculated it, the speed was around 165 FPS. Is this correct?
Justin Pasternak wrote: |
How fast does a crossbow bolt travel in Feet Per Second if the pistol crossbow has a 50 lb. draw weight? When I calculated it, the speed was around 165 FPS. Is this correct? |
Some manufacturers quote up to 200 fps. I doubt the one we have even gets quite the 165 that you calculated, but it's probably the right ballpark.
Jeff
