Wed 02 Mar, 2011 11:18 am
How do I determine the age/value of this halberd
Found in attic. Is it a valueble antique or a rusty 8th grade shop project?
Attachment: 159.33 KB
![halberd 008.jpg](files/halberd_008_182.jpg)
Posts: 1,563 Location: Upstate NY
Wed 02 Mar, 2011 12:13 pm
Some close up photos with a bit better light would be of help. It is or is meant to be a pole arm that appears to exhibit traits of both late partizans and late halberds. I can make out the remains of one langet but cannot tell from the photo if the other is there.
Wed 02 Mar, 2011 1:13 pm
Posts: 455 Location: Thailand
Thu 03 Mar, 2011 4:24 am
Looks like it's from the early 1700s, with a repaired blade. Note what appears to be a lap weld where the blade joins the base with its curved arms. The socket seems OK construction-wise for an antique partisan.
--ElJay
Posts: 55 Location: central Wisconsin, USA
Sat 19 Mar, 2011 8:02 am
I would agree that the blade has been forge-welded on with a lap weld. Two points really stick out for that, the blade has oxidized a different color than the base, which leads me to thing they are different steels, and the seam of teh weld curves to the point on one side and to the socket on the other. Unfortunately, it is difficult to determine just how the socket is welded to the base, as it seems there are remains of paint (lacquer?) or a layer of goethite hiding the weld seam.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
