Dan D'Silva
Posted: Tue 18 Jun, 2019 12:29 pm Post subject: Wide bone or bone-like grips |
Hey hello. I'm considering getting one of these:
https://www.atlantacutlery.com/companion-blade
For various reasons I'd like to give it bone grips. But all the commercially-prepped ones I've found max out at about 1-1/2 inches wide, whereas judging from a scaled photo it seems to me that the grips on this need to be at least 2 inches wide (if they're made in one piece, which I'd very much prefer). So I'm wondering if anyone knows either a) where I can get some unusually wide pieces of bone or b) what's the best substitute.
I'll consider ivory micarta if anyone can recommend it, but I've never seen it in person and online photos haven't convinced me that it looks quite the same. I'd also consider another synthetic material, or wood; anything that works, really.
Posted: Tue 18 Jun, 2019 3:32 pm Post subject: |
The easiest source is from cattle femur bones. Around 7 million of them are slaughtered in the US each year, so that gives you 28 million femurs to select from. Your nearest butcher will have plenty of them. Ask him to cut off the ends and split it for you before you take it home.
I leave my bones outside on an ant nest and let the busy critters clean them up. Then I spread them out in the sun to bleach and sterilize. Raw bone is far better than cooked bone because it is less brittle.
When cutting/sanding/working bone, make sure you wear a mask because the particles can damage your lungs.
Matthew Amt
Posted: Wed 19 Jun, 2019 6:33 am Post subject: |
Start at a pet store, dig through the large dog chew bones. The plain white clean ones, not the gummy meaty ones or those with the tasty fillings. They will tend to be curved and twisty, so the trick is to find one or two with a nice flat side. But I'm not sure what width you might find.
Otherwise, Moscow Hide and Fur might have shoulder blades or something else larger and flat:
https://www.hideandfur.com/inventory/Skulls.html
And yes, DUST MASK!
Matthew
Dan D'Silva
Posted: Wed 19 Jun, 2019 9:43 am Post subject: |
Thanks. I'll start at the Pet Smart and move on to the grocery stores and farmers market. I've got a respirator (we used them in foundry to protect against stucco dust) so no worries there.
If real bone in the right size doesn't turn up, do you like any alternative materials?
Matthew Amt
Posted: Wed 19 Jun, 2019 10:01 am Post subject: |
I've only used bone or wood, plus I think one knife handle of antler. Long ago I heard that micarta was a pretty realistic substitute for ivory, but pretty sure I've heard other opinions since. Even if it's really good, I'd still have a little of a bad taste in my mouth for using it--it's *plastic*...
Really like to try boxwood some day, it's supposed to be dreamy to work with. But expensive!
Matthew
Dan D'Silva
Posted: Thu 20 Jun, 2019 5:56 pm Post subject: |
Yeah... it's not that I want to use synthetic material, mostly I just want to find something that looks convincing if I can't get the real thing.
An art professor of mine also once mentioned substituting boxwood for bone. I remember from searches back then that it's hard to find in large pieces. My parents have a boxwood hedge that's more than 20 years old and still can't be more than a few inches thick at the root crowns. But maybe something will turn up.
Posted: Thu 20 Jun, 2019 9:23 pm Post subject: |
Planting in a hedge strangles the roots and prevents full growth. If you want full-sized plants, they need more space for root development.
I don't understand why you can't use cattle bones. I know that femurs are more than large enough for a weapon grip because I've used them myself. If you need a larger piece then use shoulder blades.
Dan D'Silva
Posted: Fri 21 Jun, 2019 2:48 am Post subject: |
Dan Howard wrote: | I don't understand why you can't use cattle bones. |
Maybe I can and maybe I can't. I haven't had a chance to check the local stores yet, and ordering online would be my second choice in this case because of the inability to examine pieces firsthand. Non-bone material is my third choice.
Michael B.
Posted: Tue 25 Jun, 2019 7:04 pm Post subject: |
I'll pick up bone from butchers, that's your best and cheapest bet. Pet stores can work, but can be spotty and expensive. I've used solid moose antler in place of bone for a white handle before, but I have lots of access to it. Holly wood is very white with a fine texture that looks like bone at first glance, I love working with it, the good pure white stuff can be quite spendy though.
www.facebook.com/bearmountainforge2
Michael Bergstrom
Dan D'Silva
Posted: Wed 26 Jun, 2019 5:46 am Post subject: |
I did wind up getting a prepared femur from Pet Valu last week. Not cheap, but judging by online prices, even two would be cheaper than a pair of boxwood or holly scales. Judging by the pieces I examined, it will be necessary to get two, because of the bone's shape. But I'm gonna see how I like cutting and shaping the first one before buying another.
Oskar Gessler
Posted: Fri 28 Jun, 2019 10:09 am Post subject: |
I would write an e-mail to these chaps https://brisa.fi/horn-bone/moose-horn.html
give them the needed measurements ask if they have some antler for you.
Antler is basically bone and especially with moose antler, even the ´porous´ inner part of it is dense and hard as hell.
If you dont like the colors, you can give it one or two hydrogen peroxide 33% treatments and you will have some pretty white bonematerial.
