Forum Index > Makers and Manufacturers Talk > Seax of Beagnoth reproduction Reply to topic
Leo Todeschini
(3 total ▮ 100% positive)
PostPosted: Fri 22 Apr, 2016 9:38 am    Post subject: Seax of Beagnoth reproduction         Reply with quote
Hi All,
Well this is the finished piece that has been going on for the last few months in the 'making of' thread here http://myArmoury.com/talk/viewtopic.php?t=32102
This is a reproduction of the very iconic Seax of Beagnoth from the British Museum. A 10thC langseax with a heavily wire inlaid blade.
I have tried to reproduce this as faithfully as I can using a blade supplied by Owen Bush, forged from his own smelted iron and shear steel and inlaid by myself.
The handle and sheath are speculative and have taken elements from various contemporary finds to create a piece 'that could have been' The handle is horn and box wood and inlaid with silver.
The sheath is leather with brass and copper decorative plates and rivets, the leather decoration is geometric and based on themes from the blade.
Overall length is 82cm/32" and weight is 1136g/2lb8oz
The weight may seem high, but the blade was supplied just a few grams over the museum weight, before the fuller was cut in, so I expect it to be very nearly identical to the original.
I hope you like it and please ask if there is anything you would like to know.
This is the text from the introduction to the original making thread
Possibly the most iconic seax is the Seax of Beagnoth in the British Museum and one I have wanted to reproduce for many years and I now have the opportunity thanks to an MA Alumni.
This is a classic 10thC Langseax with a 55cm/22" blade of the broken back type and is long and beautifully elegant. What really makes it stand out is the very elaborate Futhorc alphabet inlaid in wire on one side and the name Beagnoth on the other. There is considerable further wire inlay in geometric patterns on both sides of the blade as well as the spine.
The origin of the blade is most probably Kent as the only two renderings of the name in manuscripts are from Kent and the alphabet used, also best fits that from Southern England.
Thanks to Ryan Renfro who arranged a visit to the BM in December last year, both myself and Owen Bush were able to measure, handle and photograph the seax first hand and see the 'other' face that is almost never on display. We were also able to get a very close examination of the wire inlay. The inlay is executed in silver, brass and copper in what appears to be a fairly random manner, so that even parts of the same letter could have two different combinations of twisted wire. Although this appears random, it was deliberately done and was not, in our opinion, after use repairs. We have opted to try to replicate the inlay as faithfully as possible and this will include the apparently random materials choice.
We were also able to measure the section of the blade, which is an apple seed grind from edge to the fuller and again back toward the spine, so that the thickest section of the blade is right by the fuller, not at the edge as you may expect.
What is also interesting is that there is a partial break near the 'broken' part of the back that has caused the tip of the blade to rotate around. This means that the very distinctive and elegant form of the blade is in fact not what it would have looked like in life. We have opted to shape the blade more in line with how it would have originally been.
Completely unrelated to this visit my client contacted me to see if I was interested in making as faithful a reproduction as possible, a chance at which I jumped, and of course for me there would only be one person to contact for the blade, my old friend Owen. I discussed the project with Owen and my client and we settled on making the blade from bloomery steel that Owen smelted himself from a variety of ores. The blade construction and make up is Bloomery iron and bloomery steel, from 3 separate smelts. The steel is multiply folded magnetite bloom, circa 25,000 layers, and is a high carbon steel. Edge and body is a sandwich of high carbon bloomery steel (25,000 layer) with a mix of bloomery iron from a hematite smelt and bloomery iron from a siderite/magnetite smelt on the outside of the sandwich. The back edge is laid on its side and is again a mix of the iron and steel layers. Materials are derived from Wealden siderite from Kent, Swedish magnetite and hematite which is in fact American. The blade was then Oil hardened in high temperature oil, making for a tough and moderately hard blade, but not as remotely hard as modern steels.
We don't know the method of construction of the original piece, but Owen has followed an established method for knives of this period.
This construction method gives a distinctive look that shows through especially post etch, but this will be removed during the inlay process and can be returned by an etch after if required or the blade can be left plain; though general use will cause the pattern to show once more as the blade ages.
 Attachment: 69.34 KB
 Attachment: 113.9 KB
 Attachment: 121.03 KB
 Attachment: 152.7 KB
 Attachment: 134.36 KB
 Attachment: 130.22 KB
 Attachment: 185.26 KB
 Attachment: 80.82 KB
 Attachment: 64.24 KB
 Attachment: 135.52 KB
www.todsworkshop.com
www.todcutler.com
Last edited by Leo Todeschini on Fri 22 Apr, 2016 11:22 am; edited 1 time in total
G Ezell
PostPosted: Fri 22 Apr, 2016 10:53 am    Post subject:         Reply with quote
Magnificent work sir! Thank you for documenting the process.
This is one of those iconic blades that needed to be reproduced, and it is wonderful to see it done so well. My hat's off to you and Owen.
" I have found that it is very often the case that if you state some absolute rule of history, there will be an example, however extremely unusual, to break it."
Gabriel Lebec
https://www.facebook.com/relicforge
Houston P.
PostPosted: Fri 22 Apr, 2016 4:03 pm    Post subject:         Reply with quote
That is gorgeous. I don't think I've seen anyone reproduce a seax this nice.
...and he that hath no sword, let him sell his garment, and buy one. (‭Luke‬ ‭22‬:‭36‬)
Julien M
PostPosted: Sat 23 Apr, 2016 1:24 am    Post subject:         Reply with quote
Incredible work - Well done both Tod & Owen - splendid seax!
Jeremy V. Krause
PostPosted: Sun 24 Apr, 2016 2:01 pm    Post subject:         Reply with quote
I really can't wait to have this in-hand!
I am sure that I will be even more pleased when I see Beagnoth "in the flesh" as it were. I am trying to imagine how this seax is going to handle and I can only think it will be very assertive in blade presence.
Tod has agreed to put together a belt system for Beagnoth and so that will finish the whole affair. I will certainly post up more pictures when I receive it.
It's been great watching the entire process unfold and I thank Tod for documenting this. It really shows the care and time that went into the making of this piece.
Last edited by Jeremy V. Krause on Fri 29 Apr, 2016 1:03 pm; edited 1 time in total
Leo Todeschini
PostPosted: Tue 26 Apr, 2016 11:19 am    Post subject:         Reply with quote
And here is the belt.
There is very little evidence indeed as to how these were worn or carried and so I have made this harness really from conjecture. We know they used these distributor rings, but in many cases not really how and so I have made a system that works.
I hope you like it.
And that Ladies and Gentleman, is that.
 Attachment: 130.1 KB
www.todcutler.com
J. Nicolaysen
Likes: 32 pages
PostPosted: Tue 26 Apr, 2016 12:55 pm    Post subject:         Reply with quote
Terrific job guys, this is a great thing to see. Only thing missing are some in-hand and "around waist" in belt shots so Jeremy, we will all hunt you down somehow if you neglect those. Really great!
Patrick De Block
PostPosted: Thu 28 Apr, 2016 7:27 am    Post subject:         Reply with quote
This is fabulous and I regret I am not going to be the owner. Just plain jealous. I want it. I want it. I want it.
Jeremy V. Krause
PostPosted: Fri 20 May, 2016 12:57 pm    Post subject:         Reply with quote
So after a lot of problems with shipping and with especially with customs I finally got my newest toy. . . . .
And boy, is she a monster!
First I can't thank Owen and Tod enough for the fine work they did on this piece. It is beautiful. The blade is amazing and show all kinds of activity if you look closely. The inlay on the blade is phenomenal- just phenomenal. The silver inlay in the handle is also flawlessly executed. You can barely feel where the inlay in the wood lies since it is so tightly and neatly done.
The scabbard is also excellent- showing just the amount of detail a weapon of this status needs.
I was most surprised just how massive this blade is. It certainly has a lot of blade presence and I will echo what Tod states about how the owner of the original specimen must have had a strong arm indeed in order to bring this up to speed.
It would be devastating in the cut.
I will post up some pictures when I have more time but I just wanted to acknowledge my first impressions of this fine, fine weapon.
Here's one picture I took. Sorry for the low quality.
Patrick Kelly
(6 total ▮ 100% positive)
PostPosted: Fri 20 May, 2016 1:55 pm    Post subject:         Reply with quote
Great acquisition!
Jeremy V. Krause
PostPosted: Sat 21 May, 2016 7:27 am    Post subject:         Reply with quote
Here is a shot of Baegnoth next to my late-period broken-back seax which is also made by Tod. Hopefully you can surmise how massive this seax is. The blade on the broken-back seax is 12 inches and 22 inches on Baegnoth (I think).
And here is one showing it in hand. Sorry that the shot is at an angle so may not give the best impression of it's size.
And another of the seax and scabbard.
