Forum Index > Historical Arms Talk > Mild or Stainless for this set? Reply to topic
Ronald M
PostPosted: Thu 18 Feb, 2016 6:49 pm    Post subject: Mild or Stainless for this set?         Reply with quote
https://armstreet.com/store/armor/paladin-knight-armor-kit-etched-stainless
im thinking about this but i saw that i could get this in stainless or mild so which one would you go for and why
smiley face 123? no? lol yeah well im here cause i like...swords and weapons and stuff obv
Joshua Waters
PostPosted: Fri 19 Feb, 2016 12:45 pm    Post subject:         Reply with quote
Hi Ronald,
I would recommend going with stainless steel on this set of armour, because of the extensive etching on it. Mild steel would rust and discolor pretty fast if you don't keep it thoroughly oiled. Especially in the etched areas.
This armour is pretty much fantasy style, so I would not worry about the "accuracy" of the metal type. Stainless steel would be better still if you choose to fight in the armour.
Benedictus Dominus Deus meus.
Qui docet manus meas ad prælium, et digitos meos ad bellum.
Deus vult!
Ronald M
PostPosted: Fri 19 Feb, 2016 4:06 pm    Post subject:         Reply with quote
Joshua Waters wrote:
Hi Ronald,
well i plan to larp in it (kinda) or spar at the hema place nearby
also i can get 10% off for not getting the etching so if i did that
i also don't mind maintaining it so would stainless still be better than mild?
also how would it be better?
thanks :P
Jeff Kaisla
Reading list: 9 books
PostPosted: Fri 19 Feb, 2016 10:33 pm    Post subject:         Reply with quote
If your going to spar in it, mild might be a better option for banging out dents.
Which HEMA club are you gonna spar at? Blood and Iron?
Joshua Waters
PostPosted: Sat 20 Feb, 2016 11:39 am    Post subject:         Reply with quote
thanks :P
If you don't intend to get the etching, then mild steel might be the better choice. From my experience in HMB steel fighting, mild steel absorbs impacts better, but will deform from hard hits. Mild steel will be easier to beat dents out of later, like Jeff said. Stainless steel on the other hand, won't deform as much or often as the mild steel, but it does not absorb impacts as well as mild steel, so you might feel stings from solid blows more often. And depending on they type of stainless steel the armour is made out of, it might be difficult to beat dents out of, and there is a possibility of the stainless steel cracking if you try.
Deus vult!
Ronald M
PostPosted: Sun 21 Feb, 2016 5:05 pm    Post subject:         Reply with quote
not sure mebbe its not too far as im in vancouver
why?
