Forum Index > Historical Arms Talk > Falchion weight question Reply to topic
Karl Knisley
PostPosted: Wed 04 Feb, 2015 1:07 pm    Post subject: Falchion weight question         Reply with quote
Hello
My new falchion weighs 3.30 lbs. with a 30" long x 2' wide blade .Is that out of line with original weights?
Thanks in advance
 Attachment: 114.27 KB
Timo Nieminen
PostPosted: Wed 04 Feb, 2015 2:01 pm    Post subject:         Reply with quote
As a generalisation, about 2lbs is normal. Thin-bladed and light slicers. The longer ones and really wide-bladed ones can be heavier (e.g., the Conyers falchion is 1.3kg (2.86lb); it's 1.2 mm thick at the widest part, but there's still a lot of steel there).
The 16th and 17th century ornate ones are heavier; maybe about 2.5lbs on average, and some are over 3lbs. I think these ones are either dress swords or hunting swords. I don't know about the thickness of the blades; some are ornate with deep fullers, so they're much thicker than the plain light "fighting falchions".
Roger Hooper
PostPosted: Wed 04 Feb, 2015 3:54 pm    Post subject:         Reply with quote
Del Tin makes a very similar sword, the DT5159 That one weighs 2 lbs 4 oz. As Del Tin typically overbuilds, I'd say that yours is heavier than it should be. Yours is 2.25 inches longer, maybe that's where the extra pound is located. Big Grin
William M
Reading list: 7 books
PostPosted: Thu 05 Feb, 2015 1:41 am    Post subject:         Reply with quote
That is a really pretty Falchion! I like it a lot!!! I would prefer if it was much much lighter though. I feel that most blades these days tend to be overbuilt with big secondary bevels. I think I can see a big bevel on yours?
Harri Kyllönen
PostPosted: Thu 05 Feb, 2015 3:25 am    Post subject: Re: Falchion weight question         Reply with quote
Karl Knisley wrote:
Hello
That sounds heavy. I think your blade looks like it's of the thorpe falchion style
The historical Thorpe falchion with 80cm blade weights 0,9 kg. It was heavier originally since it has corroded but I don't think it would have weighted anywhere near 0,6kg more originally like your blade does.
Windlass replica of the Thorpe falchion weights 1,2kg but it has a 70cm blade.
Check this review if interested on the Thorpe and Windlass replica http://www.myArmoury.com/review_mrl_falc.html
Sorry for the metric system.
Karl Knisley
PostPosted: Fri 06 Feb, 2015 11:46 am    Post subject:         Reply with quote
Hello
I have felt it to be a little heavy in the recovery,but not uncomfortably so,as it was with the, Albion Ulvbane sword ,I used to have
which was about the same wieght. The handle/grip, is a bit longer than usual on a one handed sword, and the pommel
is substancial.Ernie balanced it pretty good. I wish I`d had him put a finger ring on it,with a finger over the guard, its allmost perfect. The blade has allmost a straight bevel from the spine,with a little hand sharpened apple seed-ish edge. I believe it could cut the head off a bull with it. Not that I would (ASPCA disclaimer) :-)
Alexis Bataille
PostPosted: Sat 07 Feb, 2015 2:58 am    Post subject:         Reply with quote
i have a tricky question : against plate protected target (like hitting the helmet), does a sharp blade make mor bludgeoning damage than a dull (unsharpened) one because of the grip of the "bite" in steel ?
sorry for my poor english
cheers
James Moore
PostPosted: Sat 07 Feb, 2015 5:29 am    Post subject:         Reply with quote
J.G.Elmslie's the expert on falchions, with research papers or a book in production.
perhaps he could be asked?
From what I've read and heard him say however, your one could probably lose 1/3 of its weight - I remember him showing a langes messer with a 92cm blade that weighed just 1kg!
Mark T
PostPosted: Sat 07 Feb, 2015 1:06 pm    Post subject:         Reply with quote
Hi Karl,
I admire your ongoing quest for a good single-edged single-hander!
James beat me to it - JG has documented many of the surviving falchions. I have to head out now, but do a search here and you should find a post by me that either includes his scaled images - or links to a thread that does. Not sure if the info he's already published online includes weights or not, but he's a very approachable (if busy) chap.
Schallern sind sehr sexy!
Matthew P. Adams
Likes: 8 pages
PostPosted: Sun 08 Feb, 2015 9:26 am    Post subject:         Reply with quote
Does the spine of the blade taper distally? If I saw a blade like that I would expect it to have a dramatic convex distal taper at the beginning of the swell, remaining thin up to a couple inches from the tip, and then see a bit of thickening at the spine to create a strong thrusting point.
It's a beautiful piece however you "slice" it.
And as far as I understand, a sharp hard blade would bite into a helmet, and cause more force to be transferred than a duller blade BUT attacking a helmet on purpose with a cut would be avoided if at all possible.
If it were me, I'd be more tempted to hit a helmet with the back of the blade.
Karl Knisley
PostPosted: Sun 08 Feb, 2015 10:55 am    Post subject:         Reply with quote
Hello
The blade is almost 1/4''' thick with no distal taper.This is where the extra pound is i`am sure.
Matthew P. Adams
Likes: 8 pages
PostPosted: Sun 08 Feb, 2015 11:14 am    Post subject:         Reply with quote
That plus the added pommel weight needed to balance it out.
