Jim Smith
Posted: Sat 01 Mar, 2014 12:50 pm Post subject: Conan Atlantean Sword Cleaning & Oiling (Help) |
I purchased this Atlantean sword made by Marto Toledo, back in 2007. I had it hanging on the wall for a year, and it's been in the box under my bed ever since. I took it out to look at it the other day and I noticed there are little rust specs on the blade. I need some advice on how I can get these rust specs off the blade without damaging it, will steel wool work? Also I want to clean and oil the sword before I put it back in storage. What should I use to clean the blade, and what kind of oil should I use. For some reason it won't let me upload the pictures, I can email if anybody wants to see. If someone could help me with this it would be much appreciated, thank you.
Chuck D.
Posted: Sat 01 Mar, 2014 5:07 pm Post subject: |
If the steel wool grade is fine enough, like say 0000, it should work without causing any scratches. If you like all-natural products, camellia oil makes a great blade oil, its quite similar to choji.
Phil D.
Posted: Sat 01 Mar, 2014 6:20 pm Post subject: |
If it is minor staining I would suggest just using Flitz at first. It is a bit abrasive but won't scratch,etc the metal. I have used it on what I considered rust and it completely disappeared.
Ray Harrington
Posted: Sun 02 Mar, 2014 10:22 am Post subject: |
I use MetalGlo and Burgundy, grey, or white Scotchbrite pads, it depends on how bad the rust is. If the rust is really bad and the pads are not working, I use high grit black sandpaper and do some light sanding.
Neil Langley
Jim Smith
Posted: Fri 07 Mar, 2014 4:16 pm Post subject: |
Thanks for the advice. I decided to try the flitz, it worked great took out all the little specs of rust. Are you supposed to oil the blade after polishing?
Robin Smith
Posted: Fri 07 Mar, 2014 7:05 pm Post subject: |
Jim Smith wrote: | Thanks for the advice. I decided to try the flitz, it worked great took out all the little specs of rust. Are you supposed to oil the blade after polishing? | Yes. You always want oil (or wax) on the steel to protect it.
