Forum Index > Off-topic Talk > Is EN45 steel good for a blade? Reply to topic
David Clark
PostPosted: Thu 11 Feb, 2010 11:01 pm    Post subject: Is EN45 steel good for a blade?         Reply with quote
I am just wondering if tempered en45 carbon steel is decent for a blade. This is not intended for blunt reenactment but to serve as an actual usable sword (i.e. sharpened and usable for cutting, etc).
Thanks,
David
Christopher H
PostPosted: Thu 11 Feb, 2010 11:09 pm    Post subject:         Reply with quote
Yep, it's decent... iirc quite a few British smiths use it.
Some opinions here: http://www.britishblades.com/forums/showthrea...same-steel
Peter Lyon
Reading list: 39 books
PostPosted: Fri 12 Feb, 2010 11:29 am    Post subject:         Reply with quote
I used to use en45a a lot and it makes really good sword blades - very tough but will still hold a reasonable edge. I only changed to things like SUP6 (the Japanese equivalent grade) as I could no longer get en45a in New Zealand.
Still hammering away
Maurizio D'Angelo
Likes: 3 pages
Reading list: 3 books
PostPosted: Fri 12 Feb, 2010 5:24 pm    Post subject:         Reply with quote
is not a steel that provides the same results. its range is somewhat wider
Ciao
Maurizio
