A Resource for Historic Arms and Armour Collectors
TEMPL Schiavona
Original: Venetian, circa 1750
21 people like this. Do you like this? yes no
This hilt of this complex schiavona, created by Patrick Bárta of TEMPL Historic Arms, is of a form categorized by Ewart Oakeshott as a Type 2 variant. It is characterized by its single row of chevron-shaped bars between the two diagonal upper bars forming the "basket". All the hilt's components are crafted from 300-year-old iron, showing the inclusions from the antique material, and is completely forge-welded in construction.
The various bars of the hilt are decorated with incised lines. The leather-covered grip is firmly stitched and fitted over a spiral-bound grip core. The rear quillon is left in-tact, and un-bent, as can be seen on many originals. A thumb-ring completes the hilt arrangement on the rear.
The blade is particularly detailed, having incised lines following its fuller and ricasso, stamped diamonds and crosses, and a F E R R A R A stamp within the fuller of one side of the blade. The brass pommel is of "cat's head" design and is precisely decorated with a textured background and dots surrounding its edges. An eight-pedaled "flower-shaped" boss sits centered on each face.
The blade was made in accordance with an example mounted on a schiavona in Malbork, Poland. The hilt was inspired by an example in Lysice Castle, and the original pommel and scabbard that provided inspiration can be found in a Prague museum.
The wood-cored scabbard, covered in leather and finished with decorative brass accents, was crafted to match an example found in Prague. It has decorative cutouts on its chape and a hook to hold it into its carrier.
Overall length: 39.5"
Weight: 2.85 pounds
Blade: 33.25" long; 1.375" wide tapering to 1"
Fuller: 12" long
Grip and pommel: 6" long
Point of Balance (PoB): 4.5" from cross-guard
Center of Percussion (CoP): ~22.5" from cross-guard
Maker: Patrick Bárta, TEMPL Historic Arms, Czech Republic.
This item has been retired from the collection.
Nathan Robinson's Collection
Showing this collection's retired items
76 items in total
Swords
TEMPL Schiavona
Knives and Daggers
Other Items
Show current collection »
